swap!! help guys!
hey guys i picked up this integra LS with GSR motor swapped
but i i found out that my ecu is for ls! (p75?)
so my question is i need to get a gsr ecu which is p72 right?
and also the vtec wires...im very confused with it i dont think its connected..
so the first thing is to get ecu??
Yea you can get it chipped ect. but if your not gonna mod it muc just get a stock gsr ecu the same year as the motor.
You can buy a wire harness from rywire.com to convert all the vtec ect plugs to connect to the ls harness. its no more than $160 i think.
since you say you don't think te vtec wires are hooked up! why do you think this? because if you came to the conclusion based on that the motor will not engage vtec than your wrong cause that would go back to the ls ecu.
post pics so we all can see the mayhem! than get a gsr ecu and see how it runs! see if there's check engine codes ect..
hey! thanks for the info.
anyways my friends check the wires from the engine bay and he said its not conncted..
plus i do have a p75 lol redlines at 6700 just like ls! haha
so basically i need a p72 gsr ecu
but i hope its not hard to wire all those thing
From: Pensacola, FL and every Court House in Louisiana
Zatzy
Oct 23, 2005 12:01 AM
