AT -> MT SWAP ISSUE
Old Aug 23, 2012 | 06:50 PM
xcaliberauto's Avatar
Default AT -> MT SWAP ISSUE
I had picked up an AT 2000 civic ex with a knock for $400...
Bought a parts car for about the same... the parts car was a MT with a lot less miles on it, so I decided to swap the drivetrain into my AT vehicle..
everything has gone just fine untill this problem.....
there's a starter interlock switch on my clutch pedal that wont allow the vehicle to start...
I ripped apart my MT shell and found the sensor I needed, but it has about 5 wires running through it... none of which are part of my AT harness...
Can anybody help with where these wires might lead to ? or a possibly recommend a method to override??
I would rather fix this the correct way.. I just can't seem to find any other threads or even any wire diagrams...
Thanks everybody!
p.s. please don't ask if my battery is working or my starter is functional.. thanks
Old Aug 23, 2012 | 07:14 PM
jchope's Avatar
Default Re: AT -> MT SWAP ISSUE
when i did my swap i left everything for the auto under the shifter cover and made the car think its in neural and left the clutch safety switch off
Old Aug 23, 2012 | 07:17 PM
NotAJDMFanBoy's Avatar
On my 1993, I just disconnected the interlock box under the dash. And I had to solder two thick, black wires together, but I think those were for the neutral safety switch... The rest of the wires are for the shifter lights, cruise control, cruise cancel, etc. Try that first, connecting the neutral safety switch wires together (wire it correctly after if you don't already have it that way). And disconnect the interlock box.
Old Aug 23, 2012 | 07:48 PM
I'm basicallly asking for help on a 99-00 model.... wiring issue.... complete starter interlock install.... from an at -> mt
Old Aug 23, 2012 | 07:49 PM
definitly the worst part of this swap omg ( pulls hair )
98CivB18C
25
Jun 8, 2020 03:43 PM
ferio-ichi3
Apr 2, 2013 01:46 PM
dumped94'4door
Nov 12, 2010 02:16 PM
ej2 coupe
13
Oct 17, 2007 11:29 AM
JokerX-1.6T
Jun 8, 2007 05:08 PM
