Honda CR-V & Element 2WD & 4WD Element & CR-V
crv electrical problem
Old Aug 23, 2012 | 12:15 PM
Warren Craven's Avatar
Default crv electrical problem
hi all this is my first post so please be gentle, ok so i noticed today my air con wasnt working on my 57 plate 2.0 crv itec, i read on a forum to check the air con fuses under the hood and swap to test, i did this then swapped back , but now ive got loads of problems, firstly my engine managment light is on , secondly my oil warning light is flashing amber on and off and my auto lights are staying on with the key removed and the car locked , i put the fuses back in the correct place and only swapped about the ones with the same fuse rating, hopefully someone can help me as im bricking it at the moment , thanks for any help
Old Aug 23, 2012 | 01:29 PM
MonkeyMagic's Avatar
Default Re: crv electrical problem
so.. what year crv?
Old Aug 23, 2012 | 09:22 PM
its an 07 plate
Old Aug 24, 2012 | 04:34 AM
el crapitan's Avatar
try disconnecting the battery for 5 minutes. afterward, idle for 10 minutes and perform a drive cycle. that is, 0-50kph steady. decel without braking. try and drive through a fair grade if you can. this is just to allow the ecm to relearn adaptive strategies
Old Aug 24, 2012 | 06:44 AM
hi tried that allready , car starts as soon as engine oil warning light flashes the engine light comes on, ive a feeling ive dislodged a wire os somthing inthe fuse box when i checked the modules , i noticed the modules a checked are all the same type, are they specific toi each slot if so if ive put them in the wrong slot would that cause the symptoms?
Old Aug 24, 2012 | 08:06 AM
i'd see if you can find a pdf of the service manual somewhere. with that you'll be able to troubleshoot by symptoms.
usually honda computer modules are good about being randomly disconnected.. but that's still a big automotive no-no.
Old Aug 24, 2012 | 06:59 PM
are you sure they arent relays?
how many pins?
Old Aug 24, 2012 | 08:14 PM
possibly 4 pins some horizontal some vertical, probably bad wording on my part ?anyway its the collection of larger blocks in the fuse box, i think there are 4 black 2 green 2 grey and 2 brown
Old Aug 24, 2012 | 09:24 PM
yea, relays. they should all operate the same. look at the part numbers on them. see if they all match
hustlr
Oct 14, 2014 03:46 AM
noobybowser
Nov 14, 2010 06:25 PM
yeahyeah1469
Oct 2, 2010 01:04 AM
marinersfaninmd
Acura TSX
Jun 15, 2009 07:24 PM
bicho
Feb 18, 2004 02:50 PM
