Bad Head gasket? in D16z6
Old Aug 23, 2012 | 09:10 AM
VTECwalka's Avatar
Default Bad Head gasket? in D16z6
I have a 94 civic ex, Engine was swapped about 6-7 months ago. I have had some oil leakage problems for awhile now. New valve cover gasket, New oil pan gasket. But i'm still getting a little leakage. Oil is all over the engine from the D16Z6 signature down. and i have oil in between the spaces on my header. It's not a horrible leak but i can't stand having an oil leak so i need to fix this. I started doing everything on my car my self after the new engine was swapped. So i want to replace this my self. I have never done a head job the most i have done is take off my valve cover paint it, and replace the gasket. Is this something i could do by my self and not have much of a problem? If so i'm going to need a list of tools and a little explaining on what i need to do. This engine only has 90,000 miles so id rather not replace the engine all together.
Old Aug 23, 2012 | 09:27 AM
Ryan Lwin's Avatar
Default Re: Bad Head gasket? in D16z6
Did you replace the ring seal on distributor? Did you clean the valve cover thoroughly and apply some sealant when you put on valve cover gasket? Is the oil coming out from the gap between transmission and engine block? More details and picture would be helpful. Head gasket leak is internal. Don't jump over and skip a lot of basic steps.
Old Aug 23, 2012 | 10:56 AM
VTECwalka's Avatar
I'm pretty much a noob still when it comes to engines. So basic stuff i still dont know it all. i will take pictures shortly, Sorry.
Old Aug 23, 2012 | 11:00 AM
Kohen's Avatar
Degrease the whole engine bay to be sure where your leaks are. Then post some pictures and we'll help you out.
Old Aug 23, 2012 | 03:12 PM
98.4DR.EK.D16's Avatar
x2! rule out everything simple so that you dont do a tough job or waste money or give yourself a headache when it was a simple issue
Old Aug 23, 2012 | 03:13 PM
x20! if you keep it dirty itll only get worse. if you clean it it may show you where its coming from
rovafa2002
Jul 2, 2013 07:50 AM
Adankid
14
Sep 7, 2008 06:14 AM
90CivicDaily
12
May 4, 2008 10:12 AM
j_dee1st
Apr 24, 2008 07:12 PM
SIRIUS VTEC
19
Jul 10, 2007 04:35 PM
