88-89/ 90-91 ef door cabin harness swap
I have a 90 civic dx with manual windows with a b18 swap. The whole under dash harness is all messed up. Ghetto rigged with integra harness and has a Da cluster. I wanna do it right.
Found a 89 civic ef 4 door shell wondering if the whole cabin harness from cluster,fusebox,ecu, all the way to fuel sending unit will swap with no problems. since its an 88-89
honestly it's going to be a pain if it is an lx sedan. you're losing seat belt sensors for the door on the 90, and are gaining wiring for power mirrors, locks, and windows. also you'll have to de pin/re pin the harness plugs that bolt up to the rear body harness.
vegas hoe
39
Jan 7, 2019 01:53 PM
mr_hahn73
Jan 22, 2007 08:16 PM
