Buildus Interruptus. D16 low comp engine parts. New.
The Grumpiest
Needing to get rid of some parts for a D-series build that isn't going to happen any time soon. Wife wants parts out of the house and I could use the money. Don't let that lead you to think that you can talk me into selling this stuff for cheap. I'll keep it before I give it away.
I take Paypal or you can send me a MO. I don't do checks or Paypal transactions backed by credit card. Parts are always shipped securely, quickly and insured with signature required. I'm not doing package deals unless the price is right. Don't ask me for a price. Just make a decent offer. SHIPPING NOT INCLUDED!!! These items will be shipping from the 37830 zip.
Neptune RTP in a P28 ECU & serial number for the demon. Brass thumbscrews swapped for easy access to USB port since they don't seem to come shipped with the ECU case notched out to keep the USB cable permanently installed in the ECU.
http://www.hrtuning.com/catalog/prod...a861e849eaa145
Never installed. Only hooked up to a laptop to mockup some basemaps. These retail for $594 new.
Selling for $525 OBO. Not going to go too much lower than this but I'm open. If you try and lowball I won't even respond.
This is the one Item I'm really looking to sell. The other stuff I'll hold onto if I don't get what I need out of them.
75mm Vitara pistons uncoated
FJT Revolution extended H-Beam Rods with ARP rod bolts
NPR piston rings SWH30365ZZ
ACL RACE MAIN BEARINGS5M1957H-STD & THRUST WASHERS
ACL RACE ROD BEARINGS 4B1956H
Pistons, Rods & Bearings. Sold!!! Thanks for not lowballing!!!
ARP HEADSTUDS Never used. for D16Y 208-4305 - SOLD!!! Thanks for not lowballing!!!
Z6 CRANKSHAFT - $125
Shipping will be a bitch for this one @ 30lbs.
(6) -10AN BLACK FITTINGS (x3 90* + x3 straight) and 10' of BRAIDED LINE for a catchcan setup. NOT PARTING OUT!!
Includes -12AN B&R block fitting with -12AN to -10AN adapter & (x2) weld on aluminum valve cover bungs. - SOLD!!! Thanks for not lowballing!!!
Turbo XS manual Boost controller NEW! never installed- $55
Managed to hold onto the instructions for it too!
Just found in the garage.
USED stock D-series (can't remember which) piston & rods. Don't know what to price these for. Don't know how many miles are on them. Just wanted a set to have. I think I paid $50 for the set. Make offer if you want them.
Chipped P06 ECU converted to VTEC. - $125 OBO
Has a basemap on it for a 15g, 450cc injectors and 6PSI. Cover hastily painted black. Thumbscrews for easy access to change out chips. These are getting scarcer as time goes on.
(2) Virgin P2P ECUs - $75 ea.
Use for smog or as a spare.
Not boost/build related but if anyone want this.
Chrome "Type R" valve cover - SOLD!
How much for a package deal crankshaft , rods, bearings pistons and rings shipped to frederick colorado 80530 what is the piston size and rod bolt size ? Lmk
The Grumpiest
You understand that the crank is a beast for shipping? I'll drop by the post office and weigh all this stuff. Not sure it's cost effective to even ship. The pistons are a standard 75mm bore. Not sure what you are looking for the rod bolt sizes. The rods themselves are supposed to be 137mm. Never got around to measuring them but that's what I was told.
The Grumpiest
Monday bump. Now up on Craigslist. Parts may also sell locally. If you're waiting for drops in price. Don't.
