Aftermarket H22A Header downpipe hitting oil pan.
Old Aug 22, 2012 | 01:29 PM
noz79's Avatar
Default Aftermarket H22A Header downpipe hitting oil pan.
Bought an H22A swap with some aftermarket headers. Header downpipe touches the oil pan. Does the downpipe on your H22 touch the oil pan?
Old Aug 22, 2012 | 01:41 PM
snobordboy's Avatar
Moderator
Default Re: Aftermarket H22A Header downpipe hitting oil pan.
My cheapo header didn't at first, but enough time dragging the car over speedbumps and such, it does now.
Old Aug 22, 2012 | 01:52 PM
noz79's Avatar
I never saw a speed bump in my life so that wouldn't work.
I have a DC Sports header, they have 2 different options.
I have the one that says JDM style.
Part # HHC5029
Does anybody know what the clearance to the oil pan is on the other option?
Part # HHC5009
Old Aug 22, 2012 | 01:54 PM
razorlude's Avatar
if you "After-Market" header comes with a mounting bracket at the back of the engine block i think it shouldn't lean against the oil pan anyhow.... for clearance as my mugen header,10mm or 15mm something like that....
Old Aug 22, 2012 | 02:14 PM
noz79's Avatar
Originally Posted by razorlude
if you "After-Market" header comes with a mounting bracket at the back of the engine block i think it shouldn't lean against the oil pan anyhow.... for clearance as my mugen header,10cm or 15cm something like that....
The piping under the oil pan from front to back is touching. Wasn't talking about the mounting bracket I would have hacked it off a long time ago.
Old Aug 24, 2012 | 03:58 AM
bigblockh22's Avatar
I have ran a DC header ad it clears the oil pan for sure....
Old Aug 24, 2012 | 07:56 AM
noz79's Avatar
What motor do you have USDM or JDM? If JDM whats the part number? Its going to be on the flange where it bolts up to the cylinder head.
Old Aug 24, 2012 | 07:43 PM
nus_dogg's Avatar
My Hytech replica clears the oil pan on mine.
Old Aug 25, 2012 | 01:52 AM
holmesnmanny's Avatar
i have 5009 and it clears no problem and i have h22a
I also went through two other ebay cheapies and they both cleared it. They musta bought the only one that doesn't.
Old Aug 25, 2012 | 06:19 PM
noz79's Avatar
Thanks I really appreciate the help. Gave me the part number and everything. About how much space do you have between the oil pan and the down pipe?
Old Aug 26, 2012 | 12:53 AM
I would say maybe an inch and a half or so.
Old Aug 26, 2012 | 05:14 AM
Chett_says's Avatar
I had to bend a Bisimoto header to fit correctly. It had zero clearance and needed an inch or so before it would mount up. The Hytech header fit perfect, just had to notch the crossmember edge a bit (5th gen Base).
Old Aug 26, 2012 | 06:40 PM
noz79's Avatar
That's exactly what I was hoping for. Thanks again.
How did you bend the header to fit correctly?
Old Aug 30, 2012 | 11:07 PM
I think he's saying he cut into the crossmember so the header would fit.
Old Aug 31, 2012 | 08:07 AM
THC07's Avatar
ive had hytech, rmf (replicas) both not fit my h22, hitting the oil pan.
Some heat and a bottle or floor jack properly placed jig, bend just past its memory and all was good. still using the RMF's that didnt fit.
Old Sep 1, 2012 | 07:30 AM
2quik4u's Avatar
I have had a Megan racing header and now a Hytech header and both fit fine with no issues.
Old Sep 1, 2012 | 07:59 AM
noz79's Avatar
Thanks holmesnmanny but he did say he had to bend the bisimoto headers.
Some heat? What kind of heat exactly? I was going to do this but Idk how hot I would have to get the pipe.
Thanks. If bending the pipe is a fail, this info will be a great help.
Old Sep 2, 2012 | 01:04 AM
Old Sep 2, 2012 | 05:32 PM
noz79's Avatar
1. I had to bend a Bisimoto header to fit correctly. It had zero clearance and needed an inch or so before it would mount up.
2. The Hytech header fit perfect, just had to notch the crossmember edge a bit (5th gen Base).
Looks like hes referring to two different headers here. A Bisimoto which he bent and a Hytech header. The hytech header he notched out the crossmember edge for it to fit.
Either way notching out a crossmember is not going to fix my problem.
Old Sep 2, 2012 | 09:08 PM
Yeah, you don't want to have to do that unless you have to.
Old Sep 2, 2012 | 10:22 PM
noz79's Avatar
I'm going to end up extending the headers I have with some pipe and a tig welder.
A Steak Knife
Feb 23, 2018 10:12 AM
CptHMCrunch
Jul 3, 2014 11:58 PM
98_ssbp
Aug 26, 2010 02:56 PM
slow91crx
Welding / Fabrication
Jun 7, 2006 06:07 AM
trustbuddy
Oct 20, 2004 06:40 PM
