92 civic won't turn off untill key removed
Old Aug 22, 2012 | 05:16 AM
4drctr420's Avatar
Default 92 civic won't turn off untill key removed
This problem started yesterday after I installed a steering column from a 97 civic into my 92.
My car will start fine but when I turn it off I can turn the key to the acc(I) position and my car will keep running untill I turn the key to the off position. Also there is no power running to the fan, radio, or cigarette lighter.
Also I swapped the key cylinder from my 92 into the ignition from the 97 but it was not a direct fit so I had to drill out the back of the 92 key cylinder to match the shape or the 97, could this be causing a problem?
I'm not sure if the ignition had this problem before I swapped the key cylinder, I tested it, but only made sure it started.
Old Aug 22, 2012 | 05:44 AM
Former User's Avatar
Default Re: 92 civic won't turn off untill key removed
Test the ignition switch.
Old Aug 22, 2012 | 07:46 AM
4drctr420's Avatar
I plan on testing the ignition for continuity as soon as I get home from work.
I'm starting to think that the modified key cylinder isn't the problem because the key will still click into the on(II) position.
If I do have a problem with the ignition switch is it possible to mount a 92 civic ignition switch to a 97 ignition?
Old Aug 22, 2012 | 12:30 PM
4drctr420's Avatar
I figured it out, just needed to repin the 5 pin connector on the ignition switch harness, ek and eg were pinned different, suprisingly in a way that let the car run
Tank_EM2
Honda Civic (2001 - 2005)
Aug 22, 2014 08:31 AM
Spyke5544
20
Aug 17, 2010 09:28 AM
erik66
Aug 30, 2007 07:38 AM
erik66
Aug 23, 2007 08:48 PM
