Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
06 civic si excessive fuel consumption
Old Aug 21, 2012 | 05:08 PM
flaco2007's Avatar
Icon2 06 civic si excessive fuel consumption
I need some help. i have an 06 si and using alot of fuel about 10-18mpg. am trying to find and see how many ohms the injectors are supposed to have to see if i have a leaky injector and also if any one knows how to test the air fuel sensor (o2 sensor) before i check timing. if any one had or has this issue and if its resolved yours and anybody elses imput would be very appreciated.
Old Aug 22, 2012 | 04:20 PM
flaco2007's Avatar
Default Re: 06 civic si excessive fuel consumption
anyone?
Old Aug 22, 2012 | 05:28 PM
kingteg's Avatar
What are your driving habits? How is your air filter? What is your daily commute like? Is your MIL on?
Old Aug 23, 2012 | 04:35 PM
flaco2007's Avatar
i drive normal havent kicked in vtec. shifts at 3000 rpm. work is 50 miles away thats 100 miles round trip, about 85miles highway and 15 miles city. my comute of 100 miles aday is costing 1/4 tank of fuel. air filter is still good tune up is up to date tires inflated properly according to factory spec's. no crap in my car. no mods completely stock. dont know what else to tell.
Old Aug 24, 2012 | 08:10 PM
dirty19's Avatar
Ridin Dirty in Cali
Hard to say just how you really drive this.
Found this article might shed some light on the gas mileage.
http://www.insideline.com/honda/civi...-civic-si.html
Old Aug 26, 2012 | 02:57 PM
Turtle_FA5's Avatar
Damn my car is tuned and i get like 20mpgs
Old Aug 26, 2012 | 04:39 PM
goodmaninblue's Avatar
10 Year Member
10-18mpg sounds a little bit too much for a Si. Does it have any other driveability problems? On 06 Honda, anytime there is a leak injector or a bad fuel and emission system sensor, ECM will set a P code and illuminate the MIL.
Old Aug 28, 2012 | 05:57 PM
flaco2007's Avatar
the mil is not lit. i bought a lucas depp fuel system cleaning thins and drove on a long trip 85 miles and it looked like it worked.fuel gauge whent down 2 notches. but went to work the next day on monday and today tuesday thats 200 miles and am down to a 1/4 tank of fuel. i really need some help. cant find anything on how to test for a leaky injector or how to test the o2 sensor.
Old Aug 29, 2012 | 03:59 PM
mike703's Avatar
Ok im not trying to be a dick or anything but i believe that your math is horribly wrong. like super horribly wrong. u state that youre getting 10-18mpg but yet are getting 100 miles per 1/4 tank. im averaging 29.7 mpg and i only get about 360ish miles per tank. so with your math youre getting 400 per tank which is roughly 31ish mpg. idk how youre calculating your mpg, but you should fill from empty, reset trip,drive till empty, fill up, divide miles on trip by gallons on the pump meter.
Old Aug 29, 2012 | 05:05 PM
flaco2007's Avatar
i filled my tank today and will know in about 4 days when am empty
Old Aug 31, 2012 | 09:48 PM
vladd's Avatar
If you're getting 100 miles on a 1/4 tank of gas, that means you're getting 400 miles on a full tank. That's pretty damn good, considering that the tank only holds around 13 gallons (so you're probably putting in around 10-11 gallons when filling up). 400 miles / 10 gallons = 40 MPG.
Another thing; I wouldn't try to make MPG calculations based on how much the fuel gauge changed; I'd wait until the tank is empty and gas up again, before making any calculations. Fuel gauges on Hondas are known for changing slower when the tank is closer to full, and changing faster when closer to empty.
Old Sep 2, 2012 | 10:09 AM
mike703's Avatar
way to say the exact same thing i said 2 posts up....great post count btw
Old Sep 2, 2012 | 02:53 PM
vladd's Avatar
STFU... Quit getting butt hurt over stupid ****.
Old Sep 4, 2012 | 06:59 AM
nsxmatt's Avatar
If your car was really getting that bad of fuel economy the engine light would be on. I think it's just a case of not calculating the fuel mileage correctly.
forevermemorabl
Oct 28, 2013 04:54 PM
f22 lx
May 19, 2006 01:19 PM
Mavrick
Oct 23, 2005 03:35 PM
drjulian
Sep 9, 2004 01:09 AM
pbizzlegsr
Jul 24, 2004 07:17 AM
