Misfire at cold start up.
Old Aug 21, 2012 | 04:55 PM
preludeNApower's Avatar
Default Misfire at cold start up.
Any ideas as to what could be causing a single cylinder misfire during cold start ups? Only lasts about 20 seconds then goes away after slight revving? I know what can cause misfires but has anyone experienced this kind of problem? Only when car is cold/sits over night. Plugs and wires fairly new. Thanks for any help.
Old Aug 22, 2012 | 06:31 PM
Default Re: Misfire at cold start up.
No one? I found out today it is cylinder 3. I pulled each injector to find out. I also found that I AM getting spark on all 4 wires ( did not check at plug).
Atone ever see an injector act like that?
Old Aug 26, 2012 | 04:45 PM
Bump
Old Aug 26, 2012 | 05:24 PM
InvaderTrax's Avatar
I have experienced this before. Try swapping injectors around and see if the miss follows it. If it does you'll need an injector
Old Apr 4, 2014 | 11:28 PM
jlowens76's Avatar
Having the same issue, misfire for 10-20 seconds on cold startup. Anyone ever find the issue?
Old Apr 5, 2014 | 09:10 AM
bamaland601's Avatar
usually old injectors. pull em whole rail and all, now spin it over and see if any have a weak pulse, good injectors can shoot a pulse of gas a good 5ft away so watch em.
other than that maybe cap n rotor on dizzy?
Old Apr 5, 2014 | 11:45 AM
This happened a long time ago but to update..
It was a sunk sleeve, eventually got worse and worse and then blew white smoke
Old Apr 6, 2014 | 03:58 PM
AudioFunk's Avatar
How does that happen? Just curious
Old Apr 6, 2014 | 04:29 PM
Well there are a few things that could cause it.
A. Sleeve was never fully pressed in when installed
B. the high cylinder pressures hammer on the sleeves over and over eventually causing the steel sleeve to wear away at the aluminum ledge it sits on at the bottom of the bore
C. The sleeve wasn't installed sitting with a ledge. And the it is easier for e sleeve to sink (maybes too much press fit clearance
In my scenario I had small cracks between cylinders 1-2 2-3 and 3-4 from detenation. I believe this allowed the sleeve to move around and then situation B is bound to happen.
Moral of the the story, alway install with a ledge, install with a tight press fit (to the point were the bore is heated before sleeve is pressed in), and TUNE IT RIGHT.
Brooklyn101
Oct 30, 2006 11:55 AM
OrangeBoost
May 30, 2006 10:22 AM
froggystyle14
Oct 16, 2005 06:16 AM
Yellb16crxsi
Jan 26, 2005 07:16 PM
Brolli007
Nov 18, 2002 08:48 AM
