Poormans type r help!!!!!
Old Aug 21, 2012 | 04:15 PM
CLEAN96EK's Avatar
Default Poormans type r help!!!!!
ok so i have a semi built poormans:
B16 head
BC Valve spring & Retainers
BC Stage 3 Cams
B18c1 block
pr3 pistons
Well got the motor in fired it up and it ran like a sewing machine for about a week no leaks no smoking no nothing. Then one day out of no where it bogged down and cut off on me at the light. so i had it towed to my dads shop, tried cranking it and NOTHING! So i replaced the the starter and then it would turn over but not crank. looked everything over checked spark gas and it had everything but still wouldnt crank. i then checked the timing and (to me) it looked as though it was off by one tooth. it was hard to tell because i dont have the timing cover on so i got a new belt ,which off rip was already tighter than the previous new belt, and put it on and what do you know it fired right up. BUT!!!!! Now its running way to rough. Ive checked spark plugs, wires, dizzy, injectors, fuel rail, fuel filter, and sensors. I am really stumped on this one and i am open to any and all suggestions on what it could be.
Old Aug 21, 2012 | 05:07 PM
doood's Avatar
been there done that
Default Re: Poormans type r help!!!!!
put the timing cover back on and check the timing
Old Aug 21, 2012 | 05:25 PM
njteggy's Avatar
x2 check that timing
Old Aug 21, 2012 | 06:12 PM
turbohatch96y7's Avatar
Do a compression test you probably bent a valve
Old Aug 21, 2012 | 06:45 PM
kickadog55's Avatar
agreed, timing jumping a tooth prolly f***** a valved
Old Aug 22, 2012 | 07:03 AM
CLEAN96EK's Avatar
Post Re: Poormans type r help!!!!!
i dont own one so ill have to go buy one from a buddy or sumn but im %90 sure the timing is dead on.
Old Aug 22, 2012 | 07:06 AM
CLEAN96EK's Avatar
yea this is where im in denial being that i just spent about $3000 in parts and labor i would like to hope a new motor wouldnt **** up this fast or easy.
Old Aug 22, 2012 | 04:45 PM
A bent valve isn't that bad takes about a day to fix if you do the work yourself even less.
Do a compression test and go from there if you have compression your motor should be fine. It might be another issue.
Spark,timing,fuel,or no air (clogged air filter)
Old Aug 22, 2012 | 04:50 PM
And to check the timing without the covers there's a mark for the crank on the oil pump housing.
Line the crank up with that mark and the cams should be lined up perfectly if not then your timing is off.
Old Aug 22, 2012 | 04:51 PM
If you can post a pic of the timing belt at tdc. (Top dead center) ( cam arrows pointing up)
Old Aug 24, 2012 | 04:35 PM
CLEAN96EK's Avatar
ok tomorrow ill upload a pic. but yea ive lined up the marks perfect so im sure that its dead on. but i also noticed that the motor is pretty stiff to turn over. maybe do to the upgraded valvetrain?
Loy
Dec 31, 2014 07:56 AM
RufusHonda
Oct 6, 2012 12:21 AM
88EDHatch
Feb 24, 2010 05:22 AM
XJamesX
13
May 29, 2006 10:10 PM
93civicd16z
Feb 22, 2006 10:10 AM
