Low voltage at Starter solenoid... why?
Old Aug 20, 2012 | 08:14 PM
Squatch's Avatar
Default Low voltage at Starter solenoid... why?
I have a '94 accord ex with an automatic transmission. Today she decided not to start. No crank no click no nothing. I had my battery tested and it failed. I purchased a new one and nothing changed.
I found a great thread by fcm and used his advice to observe the following...
  • The lights dim somewhat when I turn the key to start.
  • jumping 12v to the solenoid makes it engage, but the starter itself does nothing.
  • I measure 9v at the solenoid when the key is turned to START
why am I only getting 9v at the solenoid, and why won't the starter run when
I force the solenoid to engage?
Does this sound more like bad connection or bad starter?
Old Aug 21, 2012 | 08:37 PM
nus_dogg's Avatar
Default Re: Low voltage at Starter solenoid... why?
Did you check if the cables are green and what not? High resistance in the circuit?
Old Aug 21, 2012 | 08:42 PM
jdowen2's Avatar
Thouroghly clean and tighten your connections. Your solenoid could also be bad.
Jack Murphy
Jun 21, 2017 06:23 PM
azandford
Apr 29, 2010 06:03 AM
JDMB20TDA
Oct 2, 2008 08:38 PM
Integra_drk
Dec 27, 2006 10:19 AM
DAYUIZ
Jan 20, 2004 03:03 PM
