KONI And TOKICO Struts. Wide Varriety, Lots Of Applications. FAST SHIPPING!!
Logic Motorsports is proud to announce we are back with UNBEATABLE PRICES on Koni and Tokico struts. Pm with price quotes!
Did you get a quote? Show it to us, We will not be undersold!
***This pair of shocks is from the Koni "Sport" series of shocks, Koni's most popular shocks known for being one of the best (if not THE best) performance shocks available for sport cars. Colloquially called "Koni Yellows" due to their color, they are the ever evolving culmination of Koni's heritage and ingenuity. Their handling characteristics are legendary, while still managing to provide decent ride quality for daily driving. The mainstay of these shocks is their unique external adjustability, which makes them able to adapt to a wide variety of performance racing environments. As with most other Koni products, they come backed by Koni's ironclad LIFETIME warranty.
***KONIs are adjustable, which means that you can influence the behavior of the car to meet your preferences (ride comfort, handling balance, etc.). It also means that wear can be compensated. They are designed for a specific car or even special driving conditions. A KONI is not a simple copy of the original but a tailor made design to get the best handling and ride characteristics from the vehicle.
KONIs improve the ride and handling of your car. The damping characteristics are developed for each particular application. Koni's specialists keep on testing and modifying until they are convinced they reached the optimum in both handling and comfort.
********Q: What is the difference between KONI Special (red) and KONI Sport (yellow)?
A: The KONI Special (red) has been engineered to maximize the ride comfort with good handling performance for each vehicle application. The KONI Sport (yellow) typically starts at a higher initial valving baseline to give a sportier feel and work on vehicles with higher performance parts. In some instances, KONI will only offer a Special or Sport valving and not both. Some modern cars come from the factory with higher tech suspension systems and wheel/tire packages so they would move directly into the Sport range, however they are still valved to give a comfortable ride with very good handling capabilities.
***TOKICO Premium Performance shock absorbers (aka ''Tokico Blues'') have a number of features not found in other shock absorbers. These features allow TOKICO shock absorbers to provide a superior combination of handling, stability, and ride quality. --Piston Rod Guide with Teflon® coated bushing for minimal dynamic friction and good piston-rod life. --Hardened, chrome-plated, and micro-polished piston-rod for long seal life and smooth operation. --Twice drawn over mandrel pressure tube. Concentricity provides good sealing and minimal dynamic friction (drag). -- The heart of Tokico's shock absorber is their unique piston design. Tokico's multi-stage variable aperture sandwich valve system with its precision plates and precise orifice control, allows a flexibility of damping control not found in other shocks. --Tokico shock oil is specially compounded for resistance to breakdown and minimal viscosity change regardless of temperature.
***The Tokico Illumina uses a specially calibrated orifice bypass system which allows simultaneous adjustment of both compression and rebound. Each adjustment "clicks" so you always know your shock settings. The adjustment range of Tokico Illumina is one of the widest available, with 5 separate positions. Position 1 is the softest, or lowest damping force, while position 5 is the stiffest.
Thanks,
Devin@Logic Motorsports
Thanks,
Request quote:
Tokico Blues for 89 Accord (Front)
Tokico Whites for 89 Accord (Fronts)
Tokico Blues for 89 Civic (Rears)
Tokico Whites for 89 Civic (Rears)
I would like a set of front struts only for a 00 Civic SI shipped to 96929.
My car is lowered on tein springs, so I need something that's going to hold up well.
