93 gsr starting problem
Old Aug 20, 2012 | 05:07 PM
dyce_b17's Avatar
Icon2 93 gsr starting problem
Hey everyone, my problem is my car wont start up. The dash lights up but the engine wont crank up it's jux dead silence. I got a new starter in April and a new distributor last month. I had the main relay re-solder n it was running good for a month n resently it was acting up . It basically wouldn't turn on or crank my first try but it turn on rite after i release the key n tried again the other way is to push start but today its jux dead n i dont wanna have to push start every time need to kno what's wrong. O yea i even hooked a new positive wire to the starter n still nothing.
Let me know should i jux buy a new main relay or is it the ecu or jux a glitch some where???
Old Aug 21, 2012 | 06:03 AM
fcm's Avatar
fcm
Old Fart
Default Re: 93 gsr starting problem
If cranking, [starter motor not working] is the problem, the PGM-FI Main Relay is not the problem, it has nothing to do with the starter motor.
Check the starter circuit... https://honda-tech.com/forums/showth...cm+bypass+jump 94
Old Aug 22, 2012 | 05:11 PM
dyce_b17's Avatar
Thank for the help. I actually took my starter in n it was bad. But my new starter isn't working either ill run some of the test but im think starter relay or ignition relay.thanks again
Old Aug 22, 2012 | 05:22 PM
raul119's Avatar
please keep me posted on what the problem is im having the same issue with my care
Old Aug 22, 2012 | 05:57 PM
JDL2Z's Avatar
just grab a starter relay they should be cheap
Old Aug 23, 2012 | 05:33 AM
fcm's Avatar
fcm
Old Fart
Just tossing parts at a problem is an expensive way to troubleshoot a problem, find out what is wrong first, then replace the defective part. 94
Old Aug 23, 2012 | 10:18 AM
JDL2Z's Avatar
exactly how else is he supposed to find out whats wrong?
Old Aug 23, 2012 | 11:16 AM
fcm's Avatar
fcm
Old Fart
By testing. 94
Old Aug 23, 2012 | 04:13 PM
1cleanDA's Avatar
might try checking your ignition switch.
Old Aug 24, 2012 | 03:14 PM
dyce_b17's Avatar
I got a new relay didn't start st first but now its starting up quicker with less lag. But im also running a positive wire straight frm my battery to the starter. Not even using my original power wire turns out the connection which is copper is worn out. But i will replace soon. Thanks again for the advice it helps.
Old Aug 24, 2012 | 09:00 PM
mr.beeks's Avatar
wow
mr.mengo
Apr 1, 2014 07:35 PM
mikej94civex
Apr 28, 2010 07:49 PM
pooorman's type-r
Oct 7, 2008 03:07 PM
jorge59la
Aug 15, 2007 07:32 PM
Junkyard2000
Jul 4, 2005 10:55 PM
