Clutch pedal goes all the way to the floor
Old Aug 20, 2012 | 09:50 AM
98trooper's Avatar
Default Clutch pedal goes all the way to the floor
"I HATE MONDAYS"
Get in the EK this morning to go to work, start the car, push the clutch to shift to...........WTF? clutch pedal goes all the way to the floor almost before there is any pressure, cannot go into any gear.
Was fine when I parked it last night, what gives??????????
Old Aug 20, 2012 | 09:58 AM
Former User's Avatar
Default Re: Clutch pedal goes all the way to the floor
Please read the Rules sticky about proper thread titles for this forum - edited.
Old Aug 20, 2012 | 10:16 AM
JDM-sol 89's Avatar
So let us get this straight. You got in your car, pushed the clutch in (to disengage the safety switch), started the engine, let out the clutch, and then pressed the clutch again to put it in gear; that's when you noticed no pressure?
I think it's obvious you should check for leaks along your clutch line. It sounds like you have a leak somewhere in you clutch line that allowed a rapid decrease in pressure.
Old Aug 20, 2012 | 12:28 PM
Emeraldbomber's Avatar
Also check to see if fluid is spewing out of your cylinder wall on your slave cylinder and if the pushrod is on the clutch fork insert. Mine slipped off for some reason oneday. Not fun.
Old Aug 20, 2012 | 12:56 PM
98trooper's Avatar
^^None of those, looks like the master cylinder gave out.
Old Aug 20, 2012 | 01:02 PM
JDM-sol 89's Avatar
Did you look inside your car where the push-rod connects to the pedal assembly? It sometimes leaks inside the car as well.
Old Aug 20, 2012 | 01:04 PM
EsotericImage's Avatar
Retired Moderator
i was going ot say slave cylinder took a ****.. but if you already found the issue... good luck.
theres parts on the honda marketplace for cheap replacement.
http://www.hondamarketplace.com/
Old Aug 20, 2012 | 01:07 PM
strategy400's Avatar
When I saw the title I wanted to say its supposed to go all the way to the floor but yeah.
Old Aug 20, 2012 | 01:27 PM
98trooper's Avatar
^^lol thanks fellers. Really was just bitching about my Monday but the title got changed. Guess I broke the rulez.
Old Aug 22, 2012 | 04:56 AM
JDM-sol 89's Avatar
You figure out what the problem was?
Old Aug 22, 2012 | 05:03 AM
jbpnoman's Avatar
This is a tech forum. Technically, there's a place for bitching about Mondays - it's the "Official what you did to your car" thread.
Ek9b20v
12
Mar 31, 2013 01:21 PM
blacklabel14
Feb 2, 2011 08:48 PM
96 EX
11
May 15, 2009 10:29 AM
Vtec_Dude
Jun 10, 2007 10:44 AM
Nations Sickest CRX
Aug 30, 2005 03:53 PM
