Temp gauge acting strange
Old Aug 20, 2012 | 06:09 AM
crxguy406's Avatar
Default Temp gauge acting strange
Once again this is with my sohc zc swap into dx wagovan... this is the last bug I have left to work out.
Before the swap, my temp gauge worked perfect, but now it will stay pegged at the bottom until full operating temperature... at which point it will go up just a *tiny* little bit.
I've tested the sensor with a meter and it checks out, I've also tested the lead and connection and everything seems fine.
What else could I try? I really don't think its my gauge, beings it worked fine before the swap.
Old Aug 20, 2012 | 02:39 PM
crxguy406's Avatar
Default Re: Temp gauge acting strange
I also noticed today that the engine felt and smelled like it was running really hot. The fan never did kick on.
Are the fan relay sensor and temp gauge sensor linked or route through each other at all?
Old Aug 20, 2012 | 03:36 PM
4drEF's Avatar
Keyboard Humorist
Fan and gauge are not on the same circuit.
Have you tried jumping the fan switch to make sure it's working?
Very common for those to not be hooked up or fail and then the fan doesn't turn on.
Not having water will also cause this.
Old Aug 20, 2012 | 06:36 PM
Former User's Avatar
Definitely check the coolant level in the radiator and reservoir. Also bleed the cooling system.
If you ground the wire in the temp sending unit plug, does the needle in the temp gauge rise toward hot?
Littleman456
Nov 14, 2013 05:33 PM
phoenix230197
Jul 12, 2010 12:14 AM
madcivic31
Jan 29, 2010 09:23 AM
PphamEK
Apr 6, 2009 07:00 AM
si 1
Jan 2, 2006 04:48 PM
