f22 build for turbo use
hi and i plan a turbo f22 in a crx or civic
what i have
a black top f22 vtec head not sure if its a f22z2 o or f22b
both are Bore × Stroke: 85.0 × 95.0 mm only the Compression ratio separates them z2 is 9.3:1 and the b`s have 8.8:1
as said this is for turbo use i want the lower
is the block crank piston spec responsible for the Compression change?
can i use a in my space more often seen prelude/accord f20a4 block instead of f22 ?
what i have
chb93
Mar 25, 2009 03:45 PM
tcb18c5crx
Jan 15, 2004 01:43 PM
Doug684
Dec 30, 2003 09:59 AM
