2000 Honda civic d16y7 y8 head
Old Aug 19, 2012 | 04:12 PM
Quinton Ambrose's Avatar
Default 2000 Honda civic d16y7 y8 head
Ok I did I y7 bottom end with y8 head it's been timed right and valve adjust ment the car ideals at 2grand the car did have a y8 bottom and there is one wire the idk were it connects its like hooked to o2 sensor wire idk if it could of been from the y8 bottom but idk and I also did a compression test came out to 150lbs so compression ratio is like 8:1-8.5:1 is this normal
Old Aug 19, 2012 | 04:17 PM
Kohen's Avatar
Default Re: 2000 Honda civic d16y7 y8 head
150lbs across? When I did a compression test on my Y8 I wanna say it was around 140 across so you should be fine. As long as the numbers are all within 10% of each other.
Pictures of the wire? CEL?
Old Aug 19, 2012 | 04:23 PM
Yes cel I'm Gunna check tonight on what comes up it comes up under intake but all wires are plugged in to intake What could cause ideal it some times bounces from 1500 to2000
Old Aug 19, 2012 | 06:09 PM
Kohen's Avatar
What's the actual code?
Old Aug 19, 2012 | 06:13 PM
Kohen's Avatar
PLEASE do your best to speak proper English and use good spelling and grammar. It will help us help you.
Old Aug 19, 2012 | 08:17 PM
Ok sry Im preety bad with that stuff but any ways I never gotta to check the check engine light yet and that wire I was talking about comes up behind intake manifold and I was asking to see what would cause an ideal problem the timing is set and good but I just clue lest
Old Aug 19, 2012 | 08:34 PM
Kohen's Avatar
Go to AutoZone or some place and tell me what code is pulled from it.
Try to take some pictures of this wire.
Old Aug 20, 2012 | 06:10 AM
We'll I can't add a photo I'm on my iPhone idk how and I will tell you what code later on today I have to work 11-7
Old Aug 20, 2012 | 07:46 AM
coooljmp's Avatar
Sounds like an issue with the IAC to me...
Old Aug 20, 2012 | 10:15 AM
Can't be if before it worked fine before I did the y7 bottom end swap
Are all the wires the same from the y7 and y8 except the vtec
Old Aug 20, 2012 | 10:41 AM
grumblemarc's Avatar
The Grumpiest
Do they not have a Photobucket app for the Iphone?
Old Aug 20, 2012 | 11:44 AM
HondaPartsHero's Avatar
Technical Hero
yes and its actually really good
Old Aug 20, 2012 | 11:46 AM
Technical Hero
Unless your car is automatic and assuming you used the P2P ECU you have to convert the IAC from 3 wire to 2 wire, did you do that? Also you have to add the wiring for the knock sensor as well.
Old Aug 21, 2012 | 05:35 AM
No it's a Standard why dose the y7 not come with nock sensor
Old Aug 21, 2012 | 05:51 AM
kyden's Avatar
because you don't need one on a low compression motor made to run on 87.
Old Aug 21, 2012 | 06:13 AM
So coulde that throw a code
Old Aug 21, 2012 | 07:27 AM
The Grumpiest
Yes. This ^^^ isn't tripping you up is it?
Old Aug 21, 2012 | 07:51 AM
Technical Hero
Also if you didn't then you'll need to wire up the IACV as well.
zcrx2006
Nov 29, 2007 07:25 PM
r6samson
Mar 31, 2005 02:37 AM
Mr_Moos
Mar 19, 2005 08:15 PM
99hatch
Feb 1, 2005 08:36 AM
