Timing belt tension
Old Aug 19, 2012 | 01:45 PM
Boyle.R's Avatar
Default Timing belt tension
What's the best way to determine if you have enough tension on timing belt?
Old Aug 19, 2012 | 02:58 PM
a1320addict's Avatar
Default Re: Timing belt tension
A Gates 99107 Tension Gauge is useful.
Generally, 1/2" of deflection is acceptable. If you followed the correct sequence in putting your belt on, you don't have anything to worry about.
B/D/H/F
1) Set timing, tighten tensioner bolt.
2) Loosen tensioner bolt 180.
3) Rotate crank pulley counter clockwise to give you a (3) tooth offset in between your cams.
4) Tighten tensioner bolt to 40 ft/lb.
Old Aug 19, 2012 | 04:45 PM
Boyle.R's Avatar
Yes I followed sequence in manual but my block and head have been milled so deck height is lower, won't this effect the tension on belt?
Old Aug 19, 2012 | 06:36 PM
How much was taken off of each?
Theoretically yes, but you won't have it be an issue unless we are talking about a drastic amount off each.
Old Aug 19, 2012 | 09:24 PM
slowcivic2k's Avatar
Depends on the thickness of the headgasket. Some people use a thicker gasket to compensate for resurfacing. I would prefer this on a stocker, as it is the cheaper option.
Any time you remove material from the head or block you should degree the engine and use an adjustable cam gear to advance the cam back to stock. Reducing the distance between the cam and crank results in belt slack, which retards cam timing. This cannot be fixed on the tension side without mechanically compensating for the slack.
Old Aug 20, 2012 | 12:39 AM
Boyle.R's Avatar
There is about .0030" taken off between head and block. I'm fitting skunk cams so they will be dialled in.
j87w
Aug 15, 2005 12:07 AM
SpoolinEK
Dec 17, 2003 05:39 PM
InTeGrA B18b1
Aug 20, 2003 07:57 AM
Silver_Rex
May 3, 2003 09:38 PM
devonic
Mar 5, 2003 09:33 AM
