How do i put my car back to stock from turbo??
I have a 98 civic ex d16y8 with a turbo set up. I want to take all that stuff off. What oem parts are needed to make the car n/a again? Any help would be very much appreciated> Thanks
oil pan drain re-welded or replace oil pan
headers + welded/fitted to exhaust pipe
air intake
replace oil feed with knock sensor, oil pressure gauge
ecu basemap (most important or car will run like ****) www.phearable.net
map sensor
might want to get timing done also
Really isnt much, just take your time so you dont forget anything
air intake
map sensor
You will also need OEM injectors and fuel pump unless you run a chipped ECU to account for the extra fuel. Not needed whatsoever if you're going back to stock though.
It's going to be a lot of work and a lot of money if you don't already have the OEM parts. Why are you taking the turbo kit off?
the_insider
Nov 29, 2018 07:30 PM
Sprockets
Jul 11, 2016 10:20 AM
