Transmission & Drivetrain Gearboxes, Differentials, Clutches
differential question
Old Aug 19, 2012 | 01:45 AM
honda hoochie's Avatar
Default differential question
hows it going lads just wondering have a cusco 1.5 way lsd in a gearbox the is beyond repair it has 4.4 fd and i am wondering can i swap it straight into a s80 4.4 box ? the s80 box has a 14 bolt lsd and the cusco one has 10 bolts ? will i need to use the main shaft and counter shaft from the box with the cusco diff and swap the gears over from the shafts to make it work ? thanks in advance
Old Aug 19, 2012 | 05:16 PM
94EG8's Avatar
Seagull Management
Default Re: differential question
You'll need to swap the ring gear and countershaft (final drive) over from the trans with the Cusco LSD.
vtecpower00
May 12, 2010 08:23 AM
interprodavid
Mar 16, 2008 06:43 AM
bennjamin@ozhonda.com
Jul 19, 2006 04:02 AM
