quick . Will a s20 LSD box off a d15b fit my d16a8 ?
yep , quick one !
Will the s20 gearbox off a d15b (LSD equioed) fit my d16a8 (with my stock driveshafts) ?
i know the gearbox will bolt up , jsut not sure wether the driveshafts will be too big or jsut right.
thanks ben !
thanks ben !
Re: quick . Will a s20 LSD box off a d15b fit my d16a8 ? (bennjamin@ozhonda.com)
if you are taling about a d16a6, yes, but with premis.
the lsd is ring gear dependent, meaning, the lsd must match the ring gear. I amnot sure if the d16a6ring gearhad the same bolt pattern. If not, then you have to use the s20 ring gear and counter shaft.and REV.( i think rev is all the same)
then you can transfew all the gears over.
a d15bx FD is terrible, and there is absolutrely no reason why you would want it, unless you are putting out over 400 hp
Go Tigers!
Re: quick . Will a s20 LSD box off a d15b fit my d16a8 ? (court)
for the record, (pulling this out of archvies) but it will work IF and only IF you have a 4.25 final drive.
cable 4.25 countershaft + hydro lsd with the 4.25 LSD ring gear = will work
