Cam Degree Question
Old Aug 18, 2012 | 02:47 PM
cmwalker's Avatar
Default Cam Degree Question
Hey guys below i will list my build, ive got about 300 miles on my motor and im almost ready to get it tuned. I asked the machine shop that built my motor to degree in my cams and when i got my motor back they were set at +5 ex +1 in but i did not receive a list of clearances so i dont really know whats safe so when my tuner plays with my cam gears. I dont exactly want to trust that +5ex and +1 intake is the middle of duration. My question is, if i use air to lock my vtec in and spin the motor by hand, would it be fine to make a chart of OK DEGREE SETTINGS. And if so what are popular degree setting that i should try. I dont want make a chart of un neccesary settings. Thanks for your time
94 integra
81mm b18c1 (honed & decked)
Ls crank (knife edged)
Ls Rods (resized for arp rod bolts)
ARP mains (line honed)
ARP rod bolts
ACL race bearings
p30 pistons (Honda Rings)
2 layer headgasket
B16a2 head (resurfaced)
3 angle valve job
port and polish
supertech valve seals
OEM valves
Skunk2 pro series valve springs & retainers
Skunk2 pro2 cams
adjustable cam gears (+5 ex +1 in)
rc550 injectors
bolt ons:
skunk2 IM
omni power 70mm TB
CAI
PLM rmf narrow REP
full 2.5'' exhaust no cat
Hondata s300
My goal is 200whp, what do u guys think?
Old Aug 18, 2012 | 03:16 PM
doood's Avatar
been there done that
Default Re: Cam Degree Question
if the cams were properly degreed you shouldnt have to play with the gears again
Old Aug 18, 2012 | 03:35 PM
cmwalker's Avatar
the whole reason id be going out of my way to do this is because im second guessing this guys work and i dont want to **** up my motor or waste money.
Old Aug 20, 2012 | 07:36 AM
kyden's Avatar
there's no way of knowing what settings you can use without pulling the motor apart. you can't measure v2v with the head on the block.
Old Aug 21, 2012 | 12:49 PM
cmwalker's Avatar
i kno but what i was saying was to lock vtec and spin motor by hand to see if the valves touch or not at a number of different cam degree settings. this way when it comes time to dyno, if i need to adjust i kno its safe to move them...? what do you think?
Old Aug 22, 2012 | 06:58 AM
kyden's Avatar
i think that is a terrible idea. either pull the head off or leave it alone.
092eg6
Jul 12, 2010 07:39 PM
Novtec4u
13
May 3, 2008 08:15 PM
Jay_Sensing
Jan 14, 2007 07:20 PM
moosepoop21
Aug 11, 2006 12:38 PM
toEknEEg
Aug 11, 2005 09:57 PM
