89 wagon just B swapped Starts but dies after running.
Just swapped my 89 wagovan got it to start. thought timing was out the cams were adjusted so I zeroed them out. Car will start but dies after running for ten fifteen seconds the cel comes on for a second and the car dies. Also the car runs better when map is disconnected. Was the same way when the d15 was in it. Any ideas would be appricated
check your wiring for the map sensor too....are you sure you have the plugs in correct location... ive seen a few people plug stuff in wrong places and fight with a problem for weeks lol
Map sensor wiring on a 88-91 civic/crx is part of the body harness I don't think you can plug the Tps into the map sensor, it's not long enough to reach
One of my friends said crank sensor any thoughts. When I first got the swap done it took a few but it fired up and ideled on its own but when u gave it gas it acted like timeong was out and bog out.
since your using an ecu jumper you should have a loose wire (OBD1 ecu pin D4) just ground it and your check engine light code should flash on the dash board
imbrzyant
Dec 30, 2007 07:10 PM
.. ive seen people extend them to use the one that comes on the throttle body
