Honda CR-V & Element 2WD & 4WD Element & CR-V
2004 Honda CRV Engine missing.. PLZ HELP
Old Aug 17, 2012 | 11:26 PM
dwr's Avatar
dwr
Default 2004 Honda CRV Engine missing.. PLZ HELP
I have a 2004 Honda CRV with 120,000 miles. When I start it it will start up with low RPMs like its flooded for about 10 seconds. After that it idles fine. When taking off the car will miss. I have to take off slow or it will miss. When I do get it up to say 65mph it will cruse along fine that it will start missing ( best way to describe it ) when it does this its like it has no power. Then I have to let it decelerate back down to say 40mph before it will accelerate again. Its like the ignition is missing. I didnt change anything yet but made sure there wasnt any loose connections. I had just changed my air filter. I also kinda am thinking the torque converter. What do you guys think?
Old Aug 18, 2012 | 09:13 AM
el crapitan's Avatar
Default Re: 2004 Honda CRV Engine missing.. PLZ HELP
codes? being an 04, i'm sure it will have thrown something. if you have access to a scan tool capable of reading live data, the problem could be found quickly, i'm sure
Old Aug 18, 2012 | 05:48 PM
ARMED's Avatar
sparkplugs? wires?
Old Aug 22, 2012 | 09:22 AM
Photorod's Avatar
When was the last time the plugs were changed?
Old Aug 27, 2012 | 06:59 AM
dwr's Avatar
dwr
40k miles ago. I have 125K on it now and changed them somewhre around 80k.
Old Aug 27, 2012 | 06:13 PM
Old Sep 3, 2012 | 11:16 AM
dwr's Avatar
dwr
Codes P2646 ( Rocer Arm )
Code P0302
Code P0303
Code P0304
Code P0300
Code P0302
Code P0303
Old Sep 3, 2012 | 08:45 PM
apparently the p2646 is commonly caused by a clogged vtec pressure switch and solenoid screen. same "shuddering" symptoms you'd described as well.
my advice, pull the solenoid and inspect/clean the screen. give it an oil change if it's overdue. a defective switch/solenoid can also cause this. however, the only cost of cleaning the screen is time. so it's the more efficient first option
Old Sep 11, 2012 | 08:52 AM
dwr's Avatar
dwr
Thanks for your help... I was due for an oil change. I specified 5W20 as the car calls for.. And BAM.. It runs like a champ. Almost. When I start my CRV its like it has too much gas. It kinda hesitates like its flooded. Can smell the gas sometimes but not all the time. After I get the RPMs up it chokes a little than kinda cleans up and runs fine after that. If I was to stop it and start it right back up it doesnt do it. Just if I leave it sitting for a while.
Old Sep 11, 2012 | 05:07 PM
you cleared the codes afterwards, yes? recheck the codes
Rsolus
Mar 25, 2017 10:59 AM
joshuarule
Jun 29, 2015 10:31 AM
darithS
Sep 20, 2007 01:50 PM
kikacha
Jun 28, 2007 03:14 PM
spampy22
Aug 4, 2003 08:14 AM
