2 or 3 bolt post mount?
Old Aug 17, 2012 | 04:50 PM
96_coupe's Avatar
Default 2 or 3 bolt post mount?
Just blew the stock drivers side post mount during a 1-2 shift and I have to order anew one but how can you tell if it is "2 bolt" or "3 bolt"? because there are two bolts that bolt the engine-side mount to the body-side mount but there are 3 bolts the bolt the body-side of the mount to the body.. Which set of bolts am I to count?
my mount: 1997 b18b in a 1996 civic
Old Aug 17, 2012 | 04:53 PM
EJ8_Man's Avatar
Default Re: 2 or 3 bolt post mount?
Upgrade the mount with something Billet/Urethane or you will blow it again. That mount was meant for a D motor. B family requires something a little more sturdy
Old Aug 17, 2012 | 05:26 PM
96_coupe's Avatar
Yeah I'm going with a polyurethane mount kit once I know if i need the kit with the 2 or 3 bolt drivers side post mount. Thanks for the info though, I wasn't even sure if it was from a d or b
Old Aug 17, 2012 | 07:24 PM
MRGRIM's Avatar
R.I.P. Mark
the 2 or 3 bolt reffers to the bolts on the engine side
yours appears to be 2 bolt
Old Aug 17, 2012 | 11:35 PM
First.EG's Avatar
Its a two Bolt post mount. FYI the post mount is the blue bracket coming off your engine
Old Aug 18, 2012 | 09:03 AM
96_coupe's Avatar
Thanks everyone for the info, greatly appreciated. Kit ordered
lilo_goki
Jan 5, 2011 08:36 PM
550whpcivic
Sep 19, 2010 03:40 PM
grog
Apr 25, 2008 06:44 AM
Trbospnkr
Feb 8, 2004 02:05 PM
