stock 94 gsr DB8 looses power
Old Aug 17, 2012 | 03:21 PM
eg6r4eva's Avatar
Default stock 94 gsr DB8 looses power
ok well just what the title says i can be driving or just sitting in the driveway just dies out on me. ive replaced the battery, plugs, plug wires, oil change. ive also checked the alternater, starter, and checked fuses my next thing to check is the fuel pump. any other ideas to resolve would be appreciatated. thanks
Old Aug 17, 2012 | 10:23 PM
JuicedUpRice's Avatar
Default Re: stock 94 gsr DB8 looses power
im thinkin ignition control module.
next time it wont start,check for spark at the plugs and we can go from there..
Old Aug 18, 2012 | 07:47 AM
fcm's Avatar
fcm
Old Fart
When it stalls, [dies out on me] can you restart it right away?
If not, [will not restart right away] have you listened for the fuel pump priming when you turn on the ign. switch to the run position, [not all the way to start]?
If you turn on the ign. switch, does the CEL come on and then turn off after two (2) seconds?
Please answer all the above.
Both the coil and PGM-FI Main Relay are susceptible to intermittent heat related failure, so is the ICM, [Ignition Control Module] but less so, the ICM tends to work or not work, very seldom are they intermittent.
The first test is to listen for the fuel pump, the PGM-FI Main Relay intermittent failure is the most common problem on older Honda/Acura and the easiest to fix, [in most cases]...
http://www.tegger.com/hondafaq/mainrelay.html
If you do not hear the fuel pump priming, there are a few simple tests to determine if the problem is the PGM-FI Main Relay, the fuel pump itself, [also susptable to intermittent failure] or just a fuse or wiring issue.
For testing you should have a 12V test light, [not the LED type] and a paper clip.
Let me know what you find, feel free to PM me. 94
Old Aug 20, 2012 | 08:31 PM
eg6r4eva's Avatar
btw the only mods to the car's engine are a spoon drop in filter and tanabe hyper exhaust if thats any help.
ok well she will start right after but will die out again after being on for just about a minute or less. and yes cel light comes on then off. ill be checking the mail relay next thanks guys. ill be back later with how it went.
Somalie187
Feb 17, 2013 12:47 PM
toolbox21
Nov 14, 2012 04:56 PM
krazybeats
Oct 31, 2010 07:34 AM
pmey
May 26, 2009 01:11 PM
Sin-D
Nov 14, 2007 05:31 PM
