Suspension & Brakes Theory, alignment, spring rates....
Progress RSB for Honda Fit GE8 issue and question, is this just a brace?
Old Aug 17, 2012 | 10:42 AM
egyolk's Avatar
Default Progress RSB for Honda Fit GE8 issue and question, is this just a brace?
Car: 2010 Honda Fit Sport
Product: Progress Rear Sway Bar
My question, based on the design being different from any RSB i've seen: is it a real sway? is this worth getting for the track? with it produce predictable throttle lift oversteer? is this bogus and just a underbrace?
Is this really a rear sway bar? it looks like just a bar to connect the suspension points but sway bars usually are connected to the rear subframe from what I understood. The Honda Fit has a Torsion-Beam Rear Suspension so would this bar be more like a underbrace or strut bar than an actual sway bar? Please see images below of the bar, hardware and mounting points.
Please note that all this bar has is 6 bolts that are connecting the bar (3 on each side) to the perch which holds the springs....
PS: i've ran a search already, this debate is on FitFreak but I wanted your input because we are slightly more technical than folks on FitFreak.. Thanks in advance for your responces.
Image credits to Progress's website (link below) and the Honda Fit DIY websitehttp://www.progressauto.com/products/sfID1/127/sfID2/34/sfID3/93/productID/672
Old Aug 17, 2012 | 11:16 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Progress RSB for Honda Fit GE8 issue and question, is this just a brace?
The only question that would separate the bar from either being a sway bar or a chassis reinforcement is whether or not the parts it's bolted onto move.
Chassis braces limit chassis flex, a sway bar restricts motion of the suspensions independent parts.
So if those "perches" move, then yes, technically to me it's a sway bar.
Old Aug 17, 2012 | 11:25 AM
grumblemarc's Avatar
The Grumpiest
We used to call those "torsion bars" back in the day.
Old Aug 17, 2012 | 04:41 PM
egyolk's Avatar
So Solbrothers because I know you either own a fit or you know a lot about them, was the RSB for the GD3 the same design? If you had a GE8 would you get this part? I want to have predictable oversteer as I understand well enough now how to use throttle lift to get my car to rotate. I also don't mind if the ride becomes harsher from what people said on Fitfreak
egyolk
Aug 17, 2012 07:41 PM
stoneman78
15
Jul 31, 2012 07:56 PM
CALC!_JUST_du_IT!
Jul 25, 2007 06:30 PM
crazy_ham
Mar 16, 2003 06:27 AM
Duck Sauce
Dec 8, 2001 12:43 AM
