Engine Specs required: h23 crank in h22a block (deck height and rod ratio Q's)
Old Oct 16, 2002 | 04:51 AM
HotWheelz's Avatar
Default Engine Specs required: h23 crank in h22a block (deck height and rod ratio Q's)
I read somewhere that h22a rods were only .5mm longer that h23 rods.. is this true ???
I saw the other topic with an installed f22 crank in a h22 block not outputting enough oil presure . (is that going to be an issue?) aka true ?
how much does the piston extract from the deck height if you use a h23 crank in a h22a block, with h22a rods and pistons... (TDC)?????
what is the two rod ratios for h22a and h23????
I also know the h22a crank has 5 counterweights, how many does the h23 has???
does anybody know until what rpm the h23 crank is factory balanced for, how about the h22 one.???
does the h22a oil pump hookup to the h23 or other h series cranks ?
if my motor is a 93-95jdm h22a closed deck what is the h23 model crank that i need (from what make and year)???
has this been performed and tested???
is the h23 crank heavier and everything needs to be re-balanced???
any proven accelereated bearing wear because of this???
Old Oct 16, 2002 | 04:59 AM
4bidden's Avatar
Default Re: Engine Specs required: h23 crank in h22a block (HotWheelz-turboh22dx)
i have absolutely no answer to all those questions but am very interested in what some other people might have to say
Old Oct 16, 2002 | 05:18 AM
Vtec GSR95's Avatar
Default Re: Engine Specs required: h23 crank in h22a block (4bidden)
ya, i would like to know too. this sounds like some serious N/A power!! up for more info! i know ive seen someone on here with this setup.maybe they can shed some light on this subject.
frank
Old Oct 16, 2002 | 06:33 AM
satan_srv's Avatar
No. H22a rods are 143mm, H23a Rods are 141.925mm a difference of 1.075 mm. Maybe you're thinking of the stroke which is 90.7mm for H22a nad 95.0 mm for the H23?
Umm how exactly? Were the oil squirters kept?
well you have 1.075mm on the rod and 4.7mm on the stroke. Unfortunately I don't know piston specs...but if you assume the H23 and H22 standard setups would have the same stock height you could interpolate them
H22a = 1.58, H23a=1.49
Factory balanced...I would say 7000 and 8000 respectively, not too much above the rev limiter, but it's more the whole block pistons/rods that are weak for higher rpms
What other H-series cranks are you speaking of? As far as I know they hook up fine. The blocks are essentially the same, H23 block even has spots for the oil squirters and doesn't need to be tapped/drilled like the LS/VTEC
Can't confirm but I think any H23 crank will do here....
I don't recommend the H23 crank/rods/pistons in an H22 block. I have seen it tested with bad results...possibly it was a bad bore/hone job, but the engine created mad blow-by and burnt oil like a ****. The engine was rebuilt with a sleeved H23 Block and is now in my car. 7000 miles and no oil loss
Lighten and balance it, you can't go wrong doing that. Get a reputable shop to do the work.
I don't think anyone has proof. But if you were to take the H23 crank etc and rev it up to 8000 regularly, even with everything upgraded, the rod angularity and speeds will wear more than a stock setup with a lower rev limiter.
Roul Rosenow
May 28, 2013 08:54 AM
H22CIVIC
Dec 7, 2009 05:22 AM
koreachangsu
Aug 28, 2008 03:14 PM
hondacc90
Apr 14, 2008 03:25 PM
migo
Dec 29, 2001 06:11 PM
