Which Shift Linkage Would Work On EK SEDAN 1998
Doing a jdm b16a into my 1998 ek sedan. AUTO TO MANUAL
I been researching which shift linkage would fit into my 98 ek sedan but i get all the same answers or answers that dont come up to a solution
94-01 Integra people say it works but others say it hits the inner boot wall from 2 & 4 so it doesnt work?
92- integra not sure havent come up with any anwers
99-00 SI 100% works
Can someone please verify "that has done it before" which would work or which woundnt!
YES IM A NOOB FIRST SWAP!
99-00 SI 100% works
The 94-01 Integra is a DC2, it will work just fine. The only people that ever have fitment issues, are usually ones with custom exhausts if not positioned properly....and of coarse that isn't so hard to get readjusted
So I can get any integra from 94-01 doesn't matter if it's gsr,type r , Ls 2 door or 4 door..etc?
you can use all of the b series shifters from 94-01 integra
the only diffrence is JDM type R are made from chrom-moly thicker tube making them lighter than stock and dont have throw weights to keep them lighter
also the R gear stick has a shorter throw
and if you mesure the 2 together you will see the diffrence is from the pivot ball to the shift rod pivot
but how would i know ...I own a 99 CTR
my other half owns an 99 ITR
Sorry, but the ITR shifter is the SAME dimensions as any other RS, LS, or GSR shifter
Here is a picture i have as a good comparison
Left to Right: MFactory, 94-01 Integra, and 00-01 Integra type-R
