part number for 40/40 valve eg hatch
i'll answer ya, then criticize.
you can pick a 40/40 up out of a da in a junkyard, then just simply swap the mounting brackets over
the part number is 46210-SR3-962, and it looks to be around 142 from majestic.
now, im not saying taking abs out is stupid, but believing you can drive a car better without it than with it is. basically your tires have the MOST traction when they are not sliding. when you slam on the brakes and they lock up, they have no traction. that is why people used to pump them- so they would grip, slip, grip slip. not only does the car slide, but when your tires lock up, you lose the ability to steer. now with abs, the valve pumps them for you. abs accomplishes the same thing as pumping the brakes except much faster, more precise and wheel units can be regulated individually. about 15-20x faster or nearly hundreds of times a second.. if you think you can do that yourself, by all means, but at least understand that they've put hundreds of thousands of dollars, and years of studying and what not into perfecting abs- they come on cars for a reason.
ftr, i dont have abs
spoonb16b
Mar 6, 2015 02:36 PM
phantom_sol
Oct 5, 2003 10:22 AM
