Neukin RamHorn,TIAL,GT35R,CTR cams,B16 Head,780cc injectors,AEBS manifold,Greddy CARB
Old Aug 15, 2012 | 11:54 AM
"NastIE Garage"'s Avatar
Default Neukin RamHorn,TIAL,GT35R,CTR cams,B16 Head,780cc injectors,AEBS manifold,Greddy CARB
Hello , decided to part out my motor and turbo kit. Going H2B so no need for any of it. Any questions please call or text for fastest response (909)539-7436. All parts are located at NastIE Garage motorworks 1649 East mission Blvd, pomona ca, 91766 ...Thanks Nate
Neukin B series ram horn with TIAL "46"mm not 44 like the title sais, four bolt wastegate and dump tube $800 obo
AEBS B16 polished intake manifold with Ported, and port matched ITR throttle body and thermal throttle body gasket. SOLD
96 B16 cylinder head, 500 miles sense rebuild. Port and polished, BLOX dual valve train, supertech valves, 3 angle valve job, New OEM Honda exhaust valve guides,new OEM Honda valve seals, resurfaced 5 thousands. hot tanked and bead blasted,complete, minus cams. SOLD
Godspeed Gt35R turbo, 70 cold, .68 exhaust. 4 bolt, Whitfield racing oil restrictor in it, 5 miles on it max. comes with 4 bolt 3" Neukin down pipe. $400
Precision 780cc injectors, peak and hold. needs resitor box, 500 miles on them SOLD
00 CTR , ITR cams with stock cam gears SOLD!!!!
GM 3 bar map sensor with plug, and Turbonetics manual boost controller $50 each
OBD1 B16 distributor , with MSD blaster external coil wired up $150
JDM B16A block, just rebuilt for street turbo. 5 miles on block. only started it up and drove in our business complex a few times to check for leaks. Stock bore, just hot tanked and re honed, USDM GSR pistons, puts compression around 9:1, Stock rods with ARP rod bolts, micropolished crank, ACL race bearings, oil pan tapped for turbo, Whitfield oil sandwich plate with oil line, new ITR oil pump ported for more oil flow, new timing belt. $800 OBO
GSR valve cover wrinkle painted black with breather bungs on it, breather lines, and Greddy oil catch can with breather filter on top. $150
Eldelbrock high flow B series fuel rail, with fuel pressure gauge on it. $100
No name turbo piping with real Greddy Blow off valve, also has the Greddy Street/CARB legal turbo kit sticker on the piping and big godspeed front mount intercooler. Piping fits EG/DC with no problems. I have all the paper work for the Greddy Carb sticker. Never had a issue being turbo with cops with the sticker and paper work. $350 for all piping and intercooler .
Golden Eagle B16 head studs used once SOLD!!!!
Garret boost gauge $60
Old Aug 15, 2012 | 09:13 PM
JDM_JNKY's Avatar
Default Re: Neukin RamHorn,TIAL,GT35R,CTR cams,B16 Head,780cc injectors,AEBS manifold,Greddy
bump for my ninja! papa vouches for this beast!
Old Aug 16, 2012 | 11:18 AM
ivt-t's Avatar
would take cams,pm me
Old Aug 16, 2012 | 10:28 PM
Cams sold sorry, need to edit this thread. Phone won't let me though...
Old Aug 19, 2012 | 08:41 PM
Up
Old Aug 20, 2012 | 10:57 AM
TTT, cams and head studs sold. head pending
Old Aug 22, 2012 | 10:09 AM
ttt, cylinder head pending
Old Aug 24, 2012 | 10:54 AM
ttt
Old Aug 28, 2012 | 12:19 PM
ttt
Old Sep 4, 2012 | 10:11 AM
UPUPUPUUPUUPUPUPPPUP
Old Sep 5, 2012 | 11:38 AM
ttt
Old Sep 6, 2012 | 11:39 AM
ttt
Old Sep 6, 2012 | 04:13 PM
95Sol's Avatar
waiting on a text back
Old Sep 10, 2012 | 10:19 PM
Ttt
Old Sep 12, 2012 | 05:14 PM
Ttt
"NastIE Garage"
Sep 12, 2012 05:15 PM
raverx3m
Jun 29, 2010 10:50 AM
wunfstgsr
Feb 20, 2010 05:49 PM
crvtkllr
Nov 28, 2006 06:15 PM
delux247
Sep 23, 2002 08:17 PM
