FS: Edelbrock b18c turbo kit
SOLD
Asking $1000 firm. Smog legal turbo kit w/ Garret GT28 ball bearing turbo. Used and does not come w/ injectors, manifold or ecu.
Product Information
The Most Complete Turbo Systems’ Period!
Street legal and easy to install. These kits include everything you need to give your car turbocharged performance.
No additional tuning is required when used on otherwise stock engines. The Garrett turbo comes preassembled
as one unit with a Ni-resist cast exhaust manifold and elbow. inlet oil and water lines for the simplest possible
installation. The Garrett ball bearing turbo spools up fast. works with pump gas and still makes over 60% more
power than stock. The Edelbrock exhaust manifold and elbow are designed for maximum flow at high velocity.
Performer X Street Legal Turbo Kits Include:
* Garrett ball bearing Turbo preassembled with exhaust manifold and elbow. including coolant and oil lines.
* Preassembled russell fuel and oil lines with adapters
* Large bar and plate style intercooler with TIG welded cast aluminum end tanks.
* Ceramic coated turbo piping and high flow air filter
* O-ring sealed compressor inlet/outlet pipe flanges
* All gaskets. adapters and instructions
* Tial blow-off valve
Product Information
Left click on the seller's screen name and click on "Send a private message to......"
boostedhatch85
Aug 25, 2006 02:39 PM
Quad-Damag
Jul 21, 2004 08:04 PM
HYPERTUNE-Mark
Jul 3, 2002 03:41 PM
