Turbo Part out
Changing plans on the motor build. Will update with more parts and pictures, Shipping not included unless stated. Can take more pics if necessary. All prices are OBO.
Text (Bobby) to (502) 262- 091 2.
Garrett T61/GT40. (same compressor wheel as GT35R aka GT3540R). Minimum to no shaft play at all. $450 6/7
Compressor Specs:
-GT40 (same compressor wheel as GT35R aka GT3540R)
-.70 a/r
-61mm inducer
-flow: 65 lbs/min 832cfm
-Turbine specs: T4
-Turbine wheel: P-trim / Stage 3
-T3 turbine housing
-360* thrust bearing standard
F23a1 4 cyl valve cover. Needs stripping. $20
F23a1 Intake manifold $40
Stock H22 Complete Head. Comes with a Valve cover powder coated purple $200
BN Gates H22 Timing belt $25
F22 Manual Tranny Harness. $60 shipped
Items sold:
BN Skunk2 STD Compression 1.0mm oversize Intake/Exhaust Valves SOLD
KMS Springs and Retainers (Titanium) SOLD
BN MAC Boost Control Solenoid (35A-AAA-DDBA-1BA) SOLD
BN Purple 50mm Tial Bov with V-band clamp and flange. SOLD
Precision 600hp intercooler SOLD
AEM boost gauge and AEM UEGO wideband gauge. Comes with all necessary wiring and sensors. Purchased from wite2nr. SOLD
BN Omnipower 4 bar map sensor. SOLD
OBD2 to OBD1 conversion harness SOLD
B18/B16 H22 VTEC VALVE SPRING COMPRESSOR used twice. SOLD
BN Silver Tial 38mm wastegate with fire ring. SOLD
P28 w/ Neptune RTP. Includes Demon Serial # and Software License Key via email. SOLD
H22 Intake Manifold SOLD
BN Fel-pro H22a Exhaust Manifold Gasket SOLD
BN Fel-pro H22a Intake Manifold GasketSOLD
BNIB GATES RACING LOW TEMP THERMOSTAT (92-96 prelude) SOLD
BN Aem Cam Gears for H series SOLD
BN H22a Arp Head studs SOLD
Turbosmart 38mm ultragate SOLD
BLITZ BLOW OFF VALVE SOLD
H22a Mini Ram Manifold. Recently repainted High temp black SOLD
H22 aem fuel rail, aem fuel pressure regulator and guage. SOLD
BN SKUNK2 PRO BILLET THROTTLE BODY. 68mm SOLD
BNIB Wicked Rear Camber kit (98-02 Accords). SOLD
BNIB 208-4307 ARP Head Studs SOLD
Garrett 57 Trim turbo T3/T4E. Very very little shaft play. 0.60 A/R, 0.63 Hot side. 5 Bolt. Bought used but never installed. SOLD
Stock H23a non-vtec head disassembled, Valve Cover painted Wrinkle Red SOLD
Ebay headers I'm assuming. Came with the car I just purchased. SOLD
H23/F22 Rods. ARP bolts. Pistons not included. SOLD
Head, Pulled off of a running motor. SOLD
Compressor Specs:
-.70 a/r
-61mm inducer
-Turbine specs: T4
-T3 turbine housing
Items sold:
