No Vtec crossover after oil change...
Old Aug 14, 2012 | 08:23 PM
FrontwheelENT's Avatar
Default No Vtec crossover after oil change...
Sup I just changed the oil on my 02 type s today. Put in 5 qts of Mobil 1 5w30 synthetic. Replaced the oil filter with a bosch filter. I do not feel or hear a vtec crossover after changing my oil. Could not filling up the oil filter with oil cause vtec not to engage? Cause I didnt fill it up. You think I need to add more oil to the engine, i was pretty low on oil before the change. Around 3-4 qts came out from the oil pan. Also, my maintenance required light flashes on startup for about 5-10 seconds. Could this be because im low on oil? I dont have a low oil pressure light on... or a check engine.
Old Aug 14, 2012 | 08:30 PM
doood's Avatar
been there done that
Default Re: No Vtec crossover after oil change...
what mods do you have? could you hear vtec before?
and no not putting oil in the filter beforehand wont cause anything. it gets oil flowing through it as soon as the engine is on.
Old Aug 14, 2012 | 08:31 PM
bonestock. and yes i heard vtec before.
Old Aug 14, 2012 | 08:35 PM
doood's Avatar
if the CEL or oil light isnt on and the car drives like before i wouldnt worry about it. check the level line on the dipstick and add if needed. 5 quarts should have been enough.
Old Aug 14, 2012 | 08:41 PM
Lol it drives like before but without vtec!! I needs the vtec lol
Old Aug 14, 2012 | 08:51 PM
doood's Avatar
it's still there
Old Aug 14, 2012 | 08:54 PM
how is it there but i dont hear it...
Old Aug 14, 2012 | 09:28 PM
doood's Avatar
Old Aug 14, 2012 | 09:33 PM
Dc4LsTeG's Avatar
EK9
Did you make sure to put vtec oil?
As doood said its most likely still working. Can you still take it to the red line?
Old Aug 15, 2012 | 07:04 AM
Yes i can take it to redline but dosent feel like vtec.
Old Aug 15, 2012 | 07:24 AM
SkoundrelUSA's Avatar
cute little bastard
Are you sure you put in 5 qts?
Old Aug 15, 2012 | 08:47 AM
I put in a jug...
Old Aug 15, 2012 | 09:48 AM
doood's Avatar
you seem to be over complicating this
Old Aug 15, 2012 | 10:21 AM
How would i clean the vtec solenoid?
Old Aug 20, 2012 | 05:30 AM
all<dc5's Avatar
To the OP, your car is fine. But next time you check to see if VTEC is still working, do it WHEN YOUR ENGINE IS HOT. When you punch the gas when your engine is still cold, VTEC will not engage, but you will still be able to take it to redline. Be careful dude, in my opinion you should wait until the ECT gauge is at least a quarter of the way up until you try to engage VTEC
v8killaz
Nov 20, 2009 03:21 PM
BLU CIVIC
Dec 4, 2008 04:41 AM
Asway
Nov 29, 2005 02:45 PM
Monkey Fing a Coconut
Oct 14, 2004 11:49 AM
94GsRacer
Sep 19, 2002 02:43 PM
