JDM B18C SiR/GSR gas mileage and compression
Old Aug 14, 2012 | 06:16 PM
cheeblez's Avatar
Default JDM B18C SiR/GSR gas mileage and compression
I have JDM B18C gsr all stock besides the intake mounted to a b16 s4c tranny. This is in a 2000 civic Si. I was curious if an average of 30 miles to the gallon is good for a b18c. Also I was curious if getting good gas mileage means you more than likely have good to average compression. I ask thy cause I haven't done a compression test yet and didn't know if good compression is related to good gas mileage
Old Aug 14, 2012 | 07:49 PM
racebum's Avatar
Default Re: JDM B18C SiR/GSR gas mileage and compression
it is actually. when compression goes down the engine is less efficient. engines have the best mpg with leakdown under 5%
30mpg is right on the money. chances are when you compression test it the numbers will be even
by the way, don't use those adapter tubes to do a compression test. numbers will be off
Old Aug 14, 2012 | 09:02 PM
cheeblez's Avatar
Thanks for the info race bum. Out of curiosity when I bought the car it had 130k miles and I thought it had the stock b16 in it but I didn't bother to check the engine stamp cause the b-series all look so similar. I bought the car from a Toyota dealer so I didn't figure to much shady business compared to a side auto dealer. But I now know a lot more about the car. The engine is a 1994 JDM B18C SiR-G. I was curious on what you thought the mileage might be on it compared to where the chassis is at (130000) and where the last owner might have swapped the b18c in. I know this would be just a complete guess but thanks if you can give me your best guess.
Old Aug 15, 2012 | 09:08 AM
racebum's Avatar
who knows. also did you check the cylinder head for the date casting?
a healthy jdm it engine will read 255lbs of compression. the gsr version has a touch less compression....would think 235-240 would be reasonable. ideally you want to see all 4 read the same.
Old Aug 15, 2012 | 01:08 PM
cheeblez's Avatar
P72-2 93 is what the first number is
Old Aug 15, 2012 | 01:09 PM
cheeblez's Avatar
is the date casting a different number than the one right underneath the valve cover above the header?
97EXB18C
May 23, 2009 11:08 PM
needforvtec
Oct 9, 2006 08:18 PM
Mugen112
Dec 28, 2005 12:48 AM
marc.ejay-twenty
Apr 15, 2004 03:56 PM
Cyber ITR
Jun 27, 2002 06:00 PM
