Sol dead even after new battery?
Old Aug 14, 2012 | 05:03 PM
HezaDelsol's Avatar
Default Sol dead even after new battery?
Basically I came home for the weekend Friday and accidentally left my lights on. Come out to go to work Monday and the car is completely dead. Whatever, I'll have my husband jump it when he gets home. Try to jump it and still absolutely nothing. Whatever, battery must be so dead it won't charge, time for a new one. Got a new battery and put it in....still nothing. Absolutely nothing happens when you turn the key. No turn over, no lights, no click. Just dead.
If it's not the battery, what could possibly be keeping the car this dead?
Old Aug 14, 2012 | 05:08 PM
habanerored06si's Avatar
Default Re: Sol dead even after new battery?
Does the car turn over?
Any lights?
Possible culprits
-Fuse
-Alternator (not charging battery)
Old Aug 14, 2012 | 05:14 PM
HezaDelsol's Avatar
No lights, no turn over. It's acting like it has a dead battery when I know the battery has juice, it's brand new. It's also odd that the old battery wouldn't jump at all.
What fuse could be causing this?
Old Aug 14, 2012 | 05:18 PM
Former User's Avatar
Clean and tighten the battery connectors and the ground wire attached to the chassis.
Do you have a mutlimeter?
Old Aug 14, 2012 | 05:22 PM
Not infront of my car to check + its evening so no sunlight.
Look for a marked fuse indicating battery or alternator.
Old Aug 14, 2012 | 05:26 PM
HezaDelsol's Avatar
Yeah it's dark and rainy here at the moment so I can't go pull the fuses and see what's up. I hope it's just the battery fuse that's blown, just wanted to check if a blown fuse would cause a total death like this.
Old Aug 14, 2012 | 06:23 PM
gzes's Avatar
Bad alt imo. Best bet is to get one off ebay. cheap on there compared to autozone. If jot its a fuse under hood
Old Aug 15, 2012 | 08:51 PM
eg2-rhd's Avatar
check all your grounds as well
Old Aug 16, 2012 | 08:26 AM
mrspeedy69's Avatar
I also say check your grounds as well. I was having this problem a while back and turns out my terminals were pretty bad. I just replaced them and the problem stopped.
Old Aug 16, 2012 | 10:47 AM
1up_Andy's Avatar
listen to this man, he is the tech god when it comes to any and all things honda.
Old Aug 16, 2012 | 01:00 PM
93delsold16z6's Avatar
Easy way to clean the battery terminals without removing them is to take quarter cup of baking soda and three quarter cup of water . Mix it up in a cup and pour over the battery corrosion (if it has any)
fyi it is safe to do and a can of coke will do the same thing
Old Aug 19, 2012 | 06:20 PM
HezaDelsol's Avatar
Sorry I didn't update sooner, but it was in fact the 80 amp battery fuse under the hood. Once I found the right fuse (at Auto Zone, it's a screw down one) and replaced it the car fired right up. So I guess it's safe to say if the car doesn't respond to ANYTHING it can be the fuse.
Old Aug 19, 2012 | 08:38 PM
A blown 80A fuse would not affect the brake lights, hazard lights, or horn.
ludachrisvt
Sep 22, 2008 11:01 AM
fw190bvi
Jul 27, 2007 09:52 PM
irebag
May 1, 2007 01:51 PM
budget
Jun 26, 2005 12:33 PM
CivicBoi
Oct 4, 2003 12:46 AM
