Accord 1990 Tap into brake light wire
Old Aug 14, 2012 | 01:22 PM
Shaun Alvarez's Avatar
Default Accord 1990 Tap into brake light wire
Homade Added Car Security
Parts Needed:
1. On & Off Switch ($4.30 RadioShack)
2. Extra Car Horn ($5 Junker)
3. About 20 Feet of Gague 16 or 18 Cable ($5 Car Audio Shop)
What I did:
Unplugged the car Baterry
Remove the Rug/cardboard that is ontop of the 3rd brake light allso remove dthe 2 back speakers.
Remove the 2 nuits on the bottom of the 3rd Brake Housing and lift it up.
Unplug the 3rd brake light wires, now cut the plug off the brake light and slice the 2 ends of the red and black wire.
Twist them back together adding the new cable in the procress then add black tape.
Mount the horn inside the back bumper i used straps to hold it in place
run the negative wire all the way to the horn along side the trim making shure you cover up all the wire
Now Before you run the positive wire to the horn ADD the on off switch hidden somewhere.
*note* if needed drill a hole from the trunk floor to run the wires to the bumper so you can hide it better.
Now make shure all your trim is on and you place the speakers and rug back on!
How to use:
Every time you get out of the car trow the switch on and when someone presses the Brake Pedal the horn will blow atracting attention from others!
Old Aug 14, 2012 | 01:45 PM
Janet@bisimoto's Avatar
Default Re: Accord 1990 Tap into brake light wire
Security Feature?
Old Aug 15, 2012 | 04:48 PM
GhostAccord's Avatar
That is a pretty slick idea.....and were the source is located in the trunk it would be harder for them to find it quickly.
Old Aug 17, 2012 | 08:43 AM
Anyone know how to make the front horn blow when the doors open and not turn off when the dome light goes off? i tryed wiring it to the dome light and it turns off instently so im thinking i need a relay or something
Old Aug 17, 2012 | 01:36 PM
Seriously..... If you want to do stuff like this it would be in your best interest to learn a thing or two about electrical circuits and relays.
Devansh Desai
Honda Accord 2018- Current
Apr 20, 2019 09:59 AM
jdmxtacy
Aug 25, 2005 07:46 PM
Integra_Nguyen
Sep 10, 2004 02:31 PM
Full Race A6
Jul 2, 2004 04:14 PM
lilman36
Audio / Security / Video
Sep 11, 2003 02:28 PM
