installed chasebays em1 harness and car doesnt start
Old Aug 14, 2012 | 01:16 PM
thedb63's Avatar
Default installed chasebays em1 harness and car doesnt start
i mean "cm1" ok so i have been doing some research for past couple days and i hope ronj chimes in because he helped me the last time i had a problem with my civic.....
im starting to get my integra back together and i have a type r motorswap in my 93 integra..
i had my car torn all apart dash and all
i put a new gas tank in
plugged all shock tower plug on drivers side in with chase bays harness adn to the ecu and starter signal
i installed the pin a7 for the fuel pump
and a13 for the cel light
i have the ground from chasebays harness hooked up to the thermosat
i have a ground going to chassi from the trans
i had to switch the wire for the starter signal plug because as soon as i turn the the key to the on position it would want to turn over so i moved from the one side of the plug to the other side
after i fixed that i noticed the cel light never comes off
also noticed that the main relay is not clicking on and i can not hear the fuel pump prime
so i tried taking the brown wire from the chase bays harness and grounding it to see if i would get it to flash me some codes......it does nothing
so the cel just stays on
also my key wont come out until i take the positive terminal off of the battery
hope someone can help me out
Old Aug 14, 2012 | 06:29 PM
thedb63's Avatar
Default Re: installed chasebays em1 harness and car doesnt start
to the very top!
Old Aug 14, 2012 | 06:30 PM
thedb63's Avatar
i made my own harness last year and my car fired up right away! i cant believe this is doing this
Old Aug 14, 2012 | 07:05 PM
KtHaNxBai's Avatar
sell me your old harness
Old Aug 14, 2012 | 07:21 PM
thedb63's Avatar
i sold it already to my buddy
Old Aug 14, 2012 | 07:24 PM
thedb63's Avatar
after doing a little bit of thinking.......there was a plug that went up into the heater core area.....i remember keeping it before i tossed the heater core...im going to dig that up and hopefully find the plug that it went to......hopefully thats whats making it no run.....i will keep you posted if thats what it is
Old Aug 15, 2012 | 05:58 AM
thedb63's Avatar
turns out its already there any more ideas still waiting ronj-ht
Old Aug 15, 2012 | 06:24 AM
thedb63's Avatar
ok im really thinking its some grounds that i might have missed.........where could the ground be for the main relay? and the fuel pump?
Old Aug 15, 2012 | 07:27 AM
thedb63's Avatar
edited the first post because i forgot to mention that my key does not come out until the the positive terminal is off the battery
Old Aug 15, 2012 | 12:16 PM
thedb63's Avatar
ok got a multimeter now i will check to see if im getting ground to where they need to be
Old Aug 15, 2012 | 06:57 PM
thedb63's Avatar
im getting ground everywhere i need to...but on my chase bays harness im not getting power to the fuel pump nor am i getting my key out of my ignition until i take the positive terminal off the battery...cel light just stays on
at a25 im supposed to have power but its getting grounded whats up with that?(checked with a probe light with the clip on the positive terminal and then touched a25 which is supposed to be power source
Old Aug 15, 2012 | 07:10 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Year civic and is it auto?
Old Aug 15, 2012 | 07:30 PM
thedb63's Avatar
it is a 93 integra and used to be auto but now manual...
i also removed my heater core all ducting the blower fan and climate controls i left the plugs all there just incase i want to go back maybe some day but i doubt it.....
could one of the these plugs that used to go somewhere have anything to do with it?
Old Aug 15, 2012 | 10:39 PM
95B18BTurbo's Avatar
If you removed all the wiring in the heater core area, there are a few plugs with wires that power other things in the car. You might want to go back and trace out what is missing. Good luck because I know all to well how much of a pain it is!
Old Aug 16, 2012 | 05:25 AM
thedb63's Avatar
ok i will mess with that now
Old Aug 22, 2012 | 04:05 AM
thedb63's Avatar
ok turns out chasebays harness had no power going to the ecu.....wasted my money going to them for a harness.....had to have tom from www.enginewiring.com personally come to my house and figure out what the F happened
Old Sep 23, 2012 | 07:22 AM
mugentuner97's Avatar
i am having the exact same promblem...what ended up fixing it?
Old Sep 23, 2012 | 08:37 AM
beecee18's Avatar
This can happen all to often utilizing aftermarket $H!T,
Sometimes things are better to leave be, cant reinvent the wheel
Old Sep 23, 2012 | 01:10 PM
thedb63's Avatar
no power wires going to the fuel pump and main relay
95turbotypeR
24
Nov 3, 2020 01:59 AM
JShull
61
Oct 12, 2017 09:42 AM
ldelgadol
Jan 21, 2016 09:19 AM
ca_db8
Sep 24, 2009 05:33 PM
