6th gen I4-->heat generated after installing heater?
Old Oct 15, 2002 | 11:09 PM
iam7head's Avatar
Default 6th gen I4-->heat generated after installing heater?
Here the situation..
I took out the oem header, there is two "heat shields" covering the cast iron
header. I am just wondering will the aftermarket header generate too much
heat under the hood? anyone have problem with it?
another thing was is it a good idea use the heat wraps(for the header)?
it's not cheap but I heard it keep the temp. inside of the hood better.
but then someone else told me not to do it because it will overheat and crack the
header itself.
which one is the right?? any idea?
Old Oct 16, 2002 | 05:07 AM
Stew Pidasso's Avatar
Default Re: 6th gen I4-->heat generated after installing heater? (iam7head)
https://honda-tech.com/zerothread?id=165763
https://honda-tech.com/zerothread?id=278689
Check out these threads on this topic...
Old Oct 16, 2002 | 02:14 PM
iam7head's Avatar
It answered most of my question.
Just one more thing to add on to this..
is it a good idea to weld the stock heat shield to my aftermarker header?
it's ceremic coated header.
Old Oct 16, 2002 | 02:48 PM
flrdaccrd's Avatar
forget the heat shield and get a vented hood
Old Oct 16, 2002 | 06:15 PM
iam7head's Avatar
Default Re: 6th gen I4-->heat generated after installing heater? (flrdaccrd)
vented hood? I'll take that with a custom turbo baby.
96hatchBoy
Oct 26, 2012 09:14 AM
VTIargentina
Dec 29, 2009 09:13 PM
jond
Aug 18, 2002 02:13 PM
satan_srv
Jul 17, 2002 01:50 PM
b18bvtec4drteg
Jul 1, 2002 01:06 AM
