d15b7 smokes -- what emissions parts can i delete?
Old Aug 13, 2012 | 08:52 PM
Tmklim's Avatar
Default d15b7 smokes -- what emissions parts can i delete?
hey guys i have a question about the breather box n the back of my d15b7.Can i just delete that thing entirely?whats that open hole go to?the problem is the civic is smoking badly and idk if its rings bc i haven't done a comp test.at any rate i replaced my pcv calve and it didn't help my smoking problem so i wa like i wonder if all that emission crap is majorly clogged.theirfore delete it since we don't have emissions in my state.can i delete the box on the back below the intake or do i need to replace with an oil catch can and do the same for the car coal canister because i heard thats for the gas tank to vent to yet i have a fuel smell in my car.thanks for all the help and insight as always guys.
Old Aug 13, 2012 | 08:56 PM
Former User's Avatar
Default Re: hey what can i delete(emissions)
Describe the problem in detail. What car? What color smoke? When does it smoke?
Old Aug 14, 2012 | 03:41 PM
Tmklim's Avatar
Default Re: d15b7 smokes -- what emissions parts can i delete?
blue smoke,itll smoke when i leave stop lights sometimes when i shift and when i stop itll catch up to me.if i get down on it itll leave a trail i promise.i know this wont fix the problem but after my rebuild id like to have eliminated some stuff from the bay
Tmklim's Avatar
d15b7 eg sedan
Old Aug 16, 2012 | 08:41 AM
mrspeedy69's Avatar
Sounds like your valve seals maybe bad.
Old Aug 16, 2012 | 05:28 PM
ej6_b18c's Avatar
check the seals and do a comp test first, as far as emmisions just google, i pops right up how to properly delete it
Old Aug 17, 2012 | 09:08 AM
JDMBart's Avatar
you can remove the black box, that is part of the stock factory airbox
Old Aug 18, 2012 | 04:01 AM
strategy400's Avatar
He's talking about the crankcase breather box not the air filter.
You should keep the pcv (positive crankcase ventilation) system in place or sludge will build up and eventually clog your oil galleys/lubrication system, cause crud to build up, oil seal leaks etc. The 'hole' comes from the crankcase/oil pan area and draws air/blow-by through the box/pcv valve to the intake to be burned. Fresh filtered air is drawn into the valve cover/engine through that little hole/hose in the corner.
Your engine smokes because it is worn (valve guides/seals/piston rings/injectors), poorly tuned (running rich/needs a tune up) or improperly configured.
If you remove the pcv system (not recommended) use synthetic oil and change it often. But really we don't want to breathe your crank fumes.
Red-Rag-B18
May 6, 2010 02:30 PM
LsTegDriver
Aug 28, 2008 07:19 PM
Project_DX
Apr 24, 2007 04:58 PM
SLOAZZ95
Sep 22, 2003 05:33 AM
Knight2000
Dec 18, 2002 08:25 PM
