need help FAST!!!!! eg coupe
i have a problem with my eg coupe. its an ex trim level with a plain dx motor. when i turn the key over i get power, but only to windows lights and such. the car will not turn over. also when i turn the key the c.e.l. is supposed to come on but won't. im not getting any power to the fuel pump or starter either, (i've already changed the main relay). and its got an ecu in that i know works. bottom line is i'm lost and i need help.. ideas anyone? thank you in advance..
check under hood fuse box (to left of battery if in front of car) and under dash fuses.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/civic-del-sol-fuse-panel-printable-copies-fuse-diagrams-here-1966666/ Scroll down to 92-95.
MGBej1503
Apr 23, 2012 09:42 PM
c5stunna
11
Feb 8, 2011 10:13 PM
