eg coupe not starting!? help plz
so im pretty good with hondas but i have never run into a problem like this
its a 1995 civic dx from canada
but the dam cars not starting
its getting fuel cause the fuel pumps buzzing when i turn the ignition.
its turning over but not firing
the dizzy is a newer remanufactured one. not sure if it works but you think it would.
ALSO none of the dash lights are turning on when the key is turned to the on position except for the battey light were usually the check engine light and oil light would turn on till the car is running??
this is weird to me any help would be awesome
thankss
thankss
Re: eg coupe not starting!? help plz
You need to check whether both top test tabs of installed fuse 15 have battery voltage to body ground. There's a good chance that it is blown.
Also test whether the Blk/Yel wire attached to the coil and igniter unit has battery voltage to body ground with the key in ON(II). If so, test the coil and igniter unit.
i did both test today still nothing but randomly the cel and oil lights came on the on position
also all fuses are good.
update..
when im turning it over it acts like it wants to start. but right when it would usually fire up it either half starts or completly stops.
any other idea's guys?
fasterfasterfaster
11-30-2008 11:22 AM
