alternative to welding for shaving bay
Old Aug 13, 2012 | 05:13 PM
KtHaNxBai's Avatar
Default alternative to welding for shaving bay
would riviting the holes shut work??? i dont see why it wouldnt.
Old Aug 14, 2012 | 10:42 AM
KtHaNxBai's Avatar
Default Re: alternative to welding for shaving bay
ttt
Old Aug 14, 2012 | 12:52 PM
HondaPartsHero's Avatar
Technical Hero
You can use grommets and plugs to fill the holes as well
Old Aug 14, 2012 | 12:53 PM
Solid9k's Avatar
what exactly are you trying to shave? your question is very broad
Old Aug 15, 2012 | 04:09 AM
Dogginator's Avatar
Daisy... Daisy...
You could probably get away with something like JB Weld to cosmetically fill the bolt holes. Like mentioned above, this question is broad.
Old Aug 15, 2012 | 06:05 PM
KtHaNxBai's Avatar
is a general question for holes in general. riviting them shut.
Old Aug 15, 2012 | 08:05 PM
Fliptard's Avatar
I tried shaving a bay without welding, any holes without threads everything just breaks right through. I used a cheap Harbor Fright welder ($100) and it works good. I also used "All Metal" body filler which is a metal based filler and ALOT stronger than plastic fillers.
Old Aug 15, 2012 | 10:35 PM
95B18BTurbo's Avatar
I could see Quiksteel putty working well for this application instead of welding or riviting.
Old Aug 16, 2012 | 08:26 AM
Double Agent's Avatar
Welding and grinding is the best way to get a smooth finish that will last. Rivets will leave bumps and won't give a very good "shaved" look, and most fillers will not stand the heat and stress in an engine bay.
slow_sihatch
16
Feb 5, 2013 03:07 PM
markD.
Paint and Body
Mar 31, 2011 05:16 PM
tepid1
Paint and Body
Apr 9, 2010 02:15 AM
dc4teg95
Paint and Body
10
Nov 23, 2009 12:59 PM
4DRmafia
Paint and Body
Aug 2, 2007 05:16 PM
