Ticking noise at idle...transmission area...
Old Oct 15, 2002 | 09:48 PM
Austin's Avatar
Default Ticking noise at idle...transmission area...
Okay...just recently I have noticed this odd ball sound, there is click-click noise that is coming from the transmission area.
What I know about the noise:
when the clutch pedal is pushed in the noise goes away
when the rpms have been raised to 900rpm+ it goes away
What I have recently changed:
JDM itr Final Drive
Comptech Al flywheel
ACT heavy duty pressure plate
Clutchnet "Kush-lok" clutch
All lube locations were lubed per the Honda manual, and all bolts were tightened to torque specs per the Honda manual.
The clutch now has ~2200 miles on it.
Austin
Old Oct 15, 2002 | 10:02 PM
tonyxcom's Avatar
Default Re: Ticking noise at idle...transmission area... (Austin)
how certain are you that it is your tranny?
Old Oct 15, 2002 | 10:06 PM
sgT's Avatar
sgT
What you hear are the engine pulses in the form of the gears clacking against
each other. normal though it doesnt happen all the time.
Old Oct 15, 2002 | 10:47 PM
Bbasso's Avatar
Default Re: Ticking noise at idle...transmission area... (sgT)
damm sgt did you just make that up?
Old Oct 15, 2002 | 11:00 PM
tonyxcom's Avatar
Default Re: Ticking noise at idle...transmission area... (tonyxcom)
The reason I ask is because I have a similar strange noise that I hear around the distributor area, or at least I think that is where its coming from. It only happens when the car is cold though. Once its warm it goes away completely. While the car is cold, a slight rpm increase will get rid of it.
I initially thought i was my valves, because I set them to the loose side of spec. So I changed to the tighter side of spec. Noise is still there.
Old Oct 16, 2002 | 01:00 AM
IVANITR's Avatar
Same sound comes from my car, I know it's from the transmission because when I press the clutch down, the noise goes away. I just lived with it, it doesnt happen all the time.
Old Oct 16, 2002 | 08:00 AM
Austin's Avatar
Almost completely positive, I had a couple of people look at it and they all confirmed that it was coming from the transmission area...I just opened the hood and asked them to find the noise.
Old Oct 16, 2002 | 08:04 AM
Austin's Avatar
Well that makes me feel better..for a second there I thought that I might have a flywheel bolt making some sort of noise, I was hoping to avoid dropping the tranny and loctiting all of the flywheel bolts.
I was also told that since it's a lightweight flywheel it could just be it making more noise than the heavier stock flywheel.
Old Oct 16, 2002 | 08:05 AM
Austin's Avatar
Default Re: Ticking noise at idle...transmission area... (IVANITR)
Sounds good to me...at high idle it disappears.
Austin
Old Oct 16, 2002 | 09:13 AM
brownman72000's Avatar
I have a 98 with 90k on it and have the same problem. Its been confirmed that its coming from the tranny. However, when I push the clutch, it also goes away. When I let off the clutch, it is always there though. It is so faint though. I never even noticed it until one day when my friend pointed it out. My flywheel is stock but i have CM stage 1. It made the noise before the clutch. A few mechanics said there is nothing to worry about at this point. Any other comments/suggestions? Thanks!
maminej
Transmission & Drivetrain
Jul 15, 2024 06:17 PM
hondatuner020
Aug 20, 2015 04:44 PM
WildChild
Oct 18, 2005 05:21 PM
Andrew 825SM
Nov 21, 2003 12:46 PM
