CRX LS limp mode help
Old Aug 12, 2012 | 05:50 PM
itsnotfast's Avatar
Default CRX LS limp mode help
As the title says, I have a buddies 90 CRX with a LS swap in it and its running in limp mode. The car previously had a mini me swap with a chipped p28 with a jumper harness. Now it wont rev passed 4k. Its a 96 engine, we're running a 94 intake Mani OBD0 dizzy and OBD0 PR4 ECU. The car runs and idles smoothly but will not rev any higher than 4k. All grounds are clean and all injectors are measuring within spec. Any help would be greatly appreciated. I'm typing this on my phone and if anyone is willing to do so, please text or call me. 302-332-9014
Old Aug 12, 2012 | 05:52 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: CRX LS limp mode help
Check engine light on?
Old Aug 12, 2012 | 05:53 PM
Technical Hero
What Injectors?
Old Aug 12, 2012 | 05:55 PM
itsnotfast's Avatar
Also I'm not very experienced with anything obd0. This engine came out of a running 89 CRX last year. The car appears to be throwing code 14 which I think may be for the IACV.
Old Aug 12, 2012 | 05:57 PM
itsnotfast's Avatar
Not sure of the injectors I do believe they came out of the mini me swap and are running closely around 2.4 ohms.
Old Aug 12, 2012 | 05:58 PM
Technical Hero
What color wires going to the IACV?
Old Aug 12, 2012 | 06:05 PM
itsnotfast's Avatar
Black yellow and blue yellow. I cheked for continuity between the iacv and. Pin a11 and it was good
Old Aug 12, 2012 | 06:39 PM
itsnotfast's Avatar
Anyone?
Old Aug 12, 2012 | 06:51 PM
Navy_Kyle's Avatar
the sensor may be bad, try unplugging it and see what happens, cuz ik when mine was unplugged it was in limp mode cuz i forgot to plug it back in after cleaning it out.
Old Aug 12, 2012 | 07:51 PM
itsnotfast's Avatar
Just tried a known good iacv and still the same.
Old Aug 12, 2012 | 08:38 PM
itsnotfast's Avatar
Should I be running the 12 ohm injectors without the resistor box?
Old Aug 12, 2012 | 09:59 PM
itsnotfast's Avatar
Help, this car needs to be road worthy by Tuesday!!
Old Aug 12, 2012 | 10:32 PM
codybuRr's Avatar
You need to make sure the TPS and MAP sensor plus aren't switched harness side, then make sure that the 2 outer wires on the TPS are flipped around correctly so the ECU doesn't read the position wide open when its actually closed.
Old Aug 13, 2012 | 06:08 PM
BIGP90CRX's Avatar
well this thread is about my 90 crx and this is an update to what we have tried.........
well i tried a diff workin dizzy and no luck ..... im still throwin either a code 4 or 14 and 14 is iacv which ive put 3 diff ones on so idk and code 4 i believe is the cps so idk..... i have a ? about the injectors im runnin 2 ohm injectors should i try the 12 ohm and maby thats it ???? and or a diff fuel rail and the tps is wired the same way as the 90 integra so idk about that but the tps should be good so please if any one has any feedback or insight let me kno ASAP please thanks ......................
Old Aug 13, 2012 | 06:17 PM
Swap'DShuttle's Avatar
Usually when running obd0 and using obd0 injectors you need a resistor box. You need to find out exactly what codes you're throwing. I don't think the Iacv is going to throw you into limp mode. When one of my injectors went out though, I was in limp mode. So an injector problem will usually cause limp mode.
Old Aug 13, 2012 | 07:00 PM
codybuRr's Avatar
also for code 4, make sure you have the B1 and B2 wires correct, try switching them on the plug or at the ecu to clear the code
Old Aug 14, 2012 | 05:33 AM
BIGP90CRX's Avatar
ok thanks ill try that and all of the injectors are working and i have a resister box ran so idk ......
Old Aug 14, 2012 | 10:36 AM
cn_bb's Avatar
what kind of cluster u using ? the REV diff between engines.
I got 90 Si cluster on my LS swapped and the REV is litle bit off compare to my friend's.
Old Aug 14, 2012 | 11:30 AM
Umm, you don't need a tach to tell you your engine isn't revving past 4k rpm. Op what are the exact codes that can be seen atm?
Old Aug 14, 2012 | 04:57 PM
itsnotfast's Avatar
Correction. It wasn't a code 14, it was code 10 and code 4. We fixed the code 10 and we still have code 4. C1 and C2 wires are blue yellow and blue green. B10 and B12 are orange and white. I'm pretty sure all the wiring is right, we've been over it like 100 times.
Old Aug 15, 2012 | 12:38 AM
Man this is tricky. This is what happened to my old hatch. All I knew was it was ignition related and I ended up converting to obd1 like my motor should have been. No shorts in any wires for dizzy? Got continuity through all of them?
Old Aug 21, 2012 | 01:45 PM
itsnotfast's Avatar
It's a little late, but I figured I'd post up that we got it fixed. The problem was in the wiring. The CPS from the distributor was not wired correctly at the ECU.
CRX-Kid11
Jan 30, 2014 12:55 PM
GroundZer0 336
Aug 17, 2009 09:18 AM
milruner
May 12, 2005 05:15 AM
milruner
May 11, 2005 03:12 AM
milruner
May 10, 2005 10:50 PM
