1990 Civic Lx, 1.5L, 5 speed, 280k, STILL driving it...
Old Aug 12, 2012 | 11:28 AM
heli_ebook's Avatar
Default 1990 Civic Lx, 1.5L, 5 speed, 280k, STILL driving it...
Old Aug 12, 2012 | 05:24 PM
sstupid's Avatar
10 Year Member
Default Re: 1990 Civic Lx, 1.5L, 5 speed, 280k, STILL driving it...
The thermal switch is under the intake manifold in the back of the block, located between number 2 and number 3 cylinders. You will notice a small rubber cover over it. It's above the oil filter, if I remember right.
The thing you're holding is a fan relay. I've never figured out which is which, but I believe the A/C fan relay is the one mounted to the fan shroud.
Be sure to check fuse 15. It's always dumb stuff like that that gets you.
Also, check G101, the grounding hub on the water neck , where the bottom radiator hose connects. That ground is infamous. Are you in Austin, perhaps? If you are, I can help you out with this.
Old Aug 12, 2012 | 07:03 PM
sstupid's Avatar
10 Year Member
I have no qualifications for automobiles. I work on semiconductor equipment. I'll do some research this week, while I'm at work. I don't get off work until Thursday. I'll PM you if I figure something out.
div1320
Honda Civic (2001 - 2005)
Mar 20, 2011 05:48 PM
Jonathan_ED3
Sep 27, 2008 10:11 AM
must32
Aug 22, 2008 03:28 PM
Run Away
Jun 7, 2008 10:12 AM
wens_crx
May 25, 2007 07:53 AM
