92 civic vx 93 b18a1 code 9 runs sluggish
car is a 92 honda civic vx hatchback
engine is a 93 b18a1
using stock vx harness
new dizzy
Starts right up but runs like crap like its missing or timing is off but I've checked it and seems right. I give the car gas and its slow to get rpms up then the engine light comes on (code 9) Swap was just done a couple days ago, any advice on where to look?
Thanks in advance, and I did a lot of searching but not much eg info with b18a1 swaps.
new dizzy
it could be many things... i put a new dizzy,coolant temp,plugs,wires, checked all the wiring from computer to dizzy, one thing you can try is run a jumper wire from the computer to the dizzy (by pass te cars wiring harness) and i solved my problem by switching the positive and negative wires on the dizzy and it works mint no codes or nothing.. hopefully this works for you as well
StewieVX
28
Apr 20, 2015 07:05 AM
bobbysteelz
Aug 4, 2003 05:07 PM
Eyes Only
Jul 6, 2003 07:06 AM
