93 del sol/b16a2 swap/chipped P28 ECU - code 9
Old Aug 11, 2012 | 02:18 PM
DelSol-B18's Avatar
Default 93 del sol/b16a2 swap/chipped P28 ECU - code 9
Just put in a b16a2 with p28 chipped to run a b16a2 and I'm throwing code 9. I heard its a distributor problem. Is this true? Also it does not feel like it has full potential, power wise. Any suggestions?
Old Aug 11, 2012 | 04:50 PM
DelSol-B18's Avatar
Default Re: 1993 del sol b16a2 code 9 problems
Anyone!?
Old Aug 11, 2012 | 04:57 PM
dpetro1's Avatar
generally code 9 means you need a new distributor. where did the engine come from? was everything in working order prior to you installing it?
Old Aug 11, 2012 | 05:08 PM
DelSol-B18's Avatar
Got it from a owner here around Toledo Ohio. You never know the condition Of the engine but he said it was all good. But obv not if I need a new dizzy.
Old Aug 11, 2012 | 05:23 PM
DelSol-B18's Avatar
Would that be the reason it doesn't feel like it has the power it should have as well?
Old Aug 12, 2012 | 05:29 AM
DelSol-B18's Avatar
Any one else?
Old Aug 12, 2012 | 06:45 AM
Former User's Avatar
1) Measure the resistance of the CYP sensor.
2) Make sure the two CYP sensor wires are properly pinned to the ECU.
3) Test the two CYP sensor wires for a short or open.
Old Aug 12, 2012 | 11:01 AM
DelSol-B18's Avatar
Default Re: 93 del sol/b16a2 swap/chipped P28 ECU - code 9
Is it safe to drive until I get it fixed? Also I have a like miss when you give is throttle it like misses or like hesitates. Could this be because of code 9? Dizzy related?
Old Aug 12, 2012 | 11:46 AM
Don't drive it until you fix code 9. The misfire and code 9 are related.
Old Aug 12, 2012 | 12:13 PM
DelSol-B18's Avatar
Ok can you walk me through how to check all that stuff you posted above
Old Aug 12, 2012 | 01:05 PM
You need a multimeter and know how to read resistance (Ohms) or continuity. The tests are straightforward.
Old Aug 12, 2012 | 01:21 PM
DelSol-B18's Avatar
Any diagrams?
Old Aug 12, 2012 | 01:23 PM
Get a digital multimeter and post a picture of it.
Old Aug 12, 2012 | 04:38 PM
DelSol-B18's Avatar
So don't drive it? It's my only car and I need transportation
Old Aug 12, 2012 | 04:41 PM
Understood, but you risk damaging the engine. It's up to you.
Old Aug 12, 2012 | 05:12 PM
DelSol-B18's Avatar
I'm gonna swap out dizzys and see if that works. You think it will?
Old Aug 12, 2012 | 05:16 PM
If you have a distributor, go ahead. It's worth a try.
But if you want to fix car problems, now is the time to learn how to use one of the most important car tools -- the multimeter.
Old Aug 12, 2012 | 06:24 PM
DelSol-B18's Avatar
Cool man. Hey thanks alot I'll let you know what happens
Old Aug 16, 2012 | 10:25 AM
DelSol-B18's Avatar
New dizzy fixed the miss and code 9!!!
TerrellK
Jun 8, 2018 12:52 PM
t57b18
Engine Management and Tuning
Dec 20, 2008 02:01 PM
viridion
Apr 29, 2006 10:56 AM
Topdawgg
Aug 11, 2005 10:40 PM
