Idle Problem D16Z6
Oks Guys.
I try to know all about the problem with the Idle around 1500, 2000 RPM, but i have the same results.
Here my results.
1.- I Clean the IACV.- Same problem.
2.- I Clean the FITV.- Same problem.
3.- I Replace the PCV Valve.- Same problem.
4.- I Restart the ECU.- Same Problem.
5.- I check Vaccum Leack and i dont Have.
I view the engine and i found something, the hose that is betweend the PCV Valve and the intake Manifold look sucked or crushed.
I dont know if the PCV Black Box is Dirty or Stuck.
Any Ideas?
Thanks
Here my results.
Any Ideas?
Thanks
Oks Guys.
Here my results.
Any Ideas?
Thanks
Here my results.
Any Ideas?
Thanks
Cant be a bad IACV its a common problem fora Honda with a bad IACV. best way you can tell if it work remove your intake/ airbox. look into the throttle body you should see a hole on the side. have your car on and cover up the hole with your finger and if it stall etc drop the rpm it work but if doesnt it mean its a bad iacv
Luis0n
14
Nov 27, 2013 08:29 AM
